Eratic engine miss
Old Jul 6, 2004 | 02:23 PM
partsisparts's Avatar
Default Eratic engine miss
I have a1988 accord with an eratic engine miss while cruising in any gear at any speed. But the miss goes away when you rest your foot on the clutch peddal just enough to disengage the cruise cancelle switch. Got any ideas?
Old Jul 6, 2004 | 11:19 PM
Schmitey's Avatar
Default Re: Eratic engine miss (partsisparts)
wtf?...weird man
I'll bump this up for you
Oh and boo ya!!! Finally a full bull member!
Old Jul 7, 2004 | 07:49 AM
bodiez's Avatar
Hit the floor!
Check your plugs and the firing area. If there is gas in there it isnt exploding right, you need new plugs.
Check your timing belt and make sure everything is ok.
Old Jul 7, 2004 | 08:19 AM
Filthy Focker!'s Avatar
Default Re: Eratic engine miss (bodiez)
It could be worn or fouled spark plugs, bad plug wires, a weak coil, dirty injectors, low fuel pressure, an air leak, etc. A bunch of stuff. Misfires are hard to diagnos, especially intermittent problems.
First, inspect the wires for obvious signs of damage (burned or cracked insulation, chaffing, contact with the exhaust manifold, loose plug boots or terminals, etc.). If the wires are ancient and show obvious signs of deterioration or damage, you’ve probably found the problem. Replace the entire wire set.
If not, start the engine, then look and listen for arcing while the engine idles. A snapping or cracking noise would tell you secondary voltage is finding a shortcut to ground. Observing the engine in the dark may help you see where the voltage is leaking. Any fireworks that are visible along the length of the cables or at the plug boots, coil tower or distributor terminals would tell you one or more wires need replaced.
I guess you will have to blindly troubleshoot it. Get your plugs out. If the plug isn’t fouled or does not have a cracked insulator, replace the plug wire and see.
sorry
fs
leon1990
Jul 7, 2012 01:00 PM
quickster
Apr 16, 2011 11:51 AM
TyfinHX
Apr 28, 2007 01:57 PM
95AccordGuy
Jul 16, 2004 02:54 AM
