will ctr pistions fit in a b16a1? what rods should i use
Old Jul 6, 2004 | 01:52 PM
HondaCivicSiR1's Avatar
Default will ctr pistions fit in a b16a1? what rods should i use
im rebuilding my b16a1 starting from the bottom up so what do u guys suggeest
Old Jul 6, 2004 | 02:42 PM
Dent Free's Avatar
Default Re: will ctr pistions fit in a b16a1? what rods should i use (HondaCivicSiR1)
CTR's will fit No problem.
Crower Econo Rods
OEM Piston rings
Get everything balanced --- (pistons, rods, crank)
Mugen Headgasket - Raises Compression by .3
Old Jul 6, 2004 | 04:56 PM
Nerologic's Avatar
stock rods with aftermarket rod blots
Old Jul 6, 2004 | 05:43 PM
michael O's Avatar
Default Re: (Nerologic)
I'm running ctr pistons in my b16a. stock rods. I had the rods shotpeened and am using arp rod bolts.
Old Jul 6, 2004 | 07:34 PM
Dent Free's Avatar
Default Re: (michaelOlson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by michaelOlson &raquo;</TD></TR><TR><TD CLASS="quote">I'm running ctr pistons in my b16a. stock rods. I had the rods shotpeened and am using arp rod bolts.</TD></TR></TABLE>
Good Set up.
Have that set up with New Oem rings and Stainless Steel valves and a 75 shot or a 100 shot (only with stronger rods) and you should run very low ET's. And add some Skunk2 Stage 2's ----- Oh My...
Old Jul 7, 2004 | 10:06 PM
soulstream's Avatar
If you use stock rods you will need 1mm shaved off each side of the rod where the wrist pin goes in.
Old Jul 7, 2004 | 10:52 PM
hahagasdcrx's Avatar
Default Re: (soulstream)
Stock rods work fine just use some ARP bolts......
Old Jul 8, 2004 | 10:42 AM
Default Re: (hahagasdcrx)
where can i get ctr pistions and and everything else i will need to do this?
Old Jul 8, 2004 | 11:07 AM
H.A.R.T b16a1crx's Avatar
Default Re: (HondaCivicSiR1)
any jdm online store search for it
Old Jul 8, 2004 | 11:31 AM
Dent Free's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaCivicSiR1 &raquo;</TD></TR><TR><TD CLASS="quote">where can i get ctr pistions and and everything else i will need to do this?</TD></TR></TABLE>
http://www.inlinefour.com/jdmhonoempis.html
http://www.kteller.com/store/index.php/cPath/68_72
http://store.yahoo.com/yhst-14....html
All it takes is a little time . . . I had them book marked already
SINBAD
12
Sep 19, 2016 11:26 PM
ef9ridda
Oct 29, 2010 08:25 PM
trrbl1bmx
Feb 18, 2006 09:56 AM
StupidSlowRSX
Jan 27, 2005 08:37 PM
vtecmonster001
Jan 13, 2005 08:12 AM
