JDM EG6 guage cluster, Dimmer Problem
Old Jul 5, 2004 | 08:52 PM
BpuTacoma's Avatar
Default JDM EG6 guage cluster, Dimmer Problem
hey, i have a JDM EG6 guage cluster, and it's really really dim, and the dimmer doesn't adjust it.
it's in a 93' CX
Old Jul 5, 2004 | 08:54 PM
crashN2u's Avatar
Default Re: JDM EG6 guage cluster, Dimmer Problem (BpuTacoma)
Did you double check that it was hooked up to your dimmer switch?
Old Jul 5, 2004 | 08:57 PM
92b16vx's Avatar
JDM clusters don't use a dimmer.
Old Jul 5, 2004 | 08:59 PM
crashN2u's Avatar
Default Re: (92b16vx)
I thought there was a way to hook them up to your dimmer.
Skip01's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92b16vx &raquo;</TD></TR><TR><TD CLASS="quote">JDM clusters don't use a dimmer.</TD></TR></TABLE>
Old Jul 5, 2004 | 09:00 PM
crashN2u's Avatar
Default Re: (Skip01)
Then I guess my friend was full of ****. He said that there was a way to ghetto rig it.
Old Jul 5, 2004 | 09:04 PM
BpuTacoma's Avatar
Default Re: (crashN2u)
well that sucks, any idea how to make the cluster brighter ?
Old Jul 5, 2004 | 09:12 PM
92b16vx's Avatar
Default Re: (BpuTacoma)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BpuTacoma &raquo;</TD></TR><TR><TD CLASS="quote">well that sucks, any idea how to make the cluster brighter ? </TD></TR></TABLE>
The EG6 cluster is just not as bright as the USDM ones, but you can make sure all the bulbs are working, other than that you'll get used to it.
Old Jul 5, 2004 | 09:33 PM
JDM SLICK's Avatar
true that...yeah the first time you stare at it at night...it seems dim...but like what he said...you'll get used to it...check your bulbs to see if they're all working to.
By the way, if the bulbs do go out, do you guys know a place that sells the amber bulbs?
I know it has a amber gel coating around them, but they seem so delicate if one will try to pull it out...
anyway, big ups for the jdm gauge clusters...
Old Jul 5, 2004 | 09:55 PM
92b16vx's Avatar
The bulbs are clear the amber comes from the cluster. I just pulled my old ones and removed the blue condom on them to replace mine that were out.
Sean @ ESG
Oct 4, 2008 06:45 PM
Weak!EG
May 7, 2007 11:07 PM
o5mar1
23
Sep 10, 2005 12:04 PM
92 EH2
Mar 20, 2005 05:22 PM
WindyIce
Apr 24, 2003 09:16 PM
