AC causing engine to overheat~
Not sure what that is..but if its within the ac itself the ac was tuned up and fixed so it shouldn't be the ac's fault. I think it might be the radiator or electrical wiring problems though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 »</TD></TR><TR><TD CLASS="quote">Is your A/c condensor fan cycling on and off?</TD></TR></TABLE>
******* A did anyone not see that post?
You need to make sure that the A/C condensor fan is kicking on as soon as you turn the A/C switch on. If it's not coming on, then there's one place to start. Check the A/C fan relayes first, fuses, etc. The fan itself could be shot as well if the relays check out okay.
Hi maybe this could help. I an from South africa and have an 1986 150 Honda carbed model with some mods. The same happened to me as you. After a took out the A/C the problem of overheating went away, bur we realised that the A/C radiator was blocked and that caused the airflowed to be influenced by heat..ext. to the radiator of the car.
Hope it helps. Just check your A/C radiator to see if it isnt blocked
