engine removal
Old Jul 5, 2004 | 09:40 AM
EFin' Kyle's Avatar
Default engine removal
i have just takin all the belts, hoses, and the head of my engine off. do i need to use and engine hoist or is there another way to get the block out?
Old Jul 5, 2004 | 09:59 AM
mr. carpenter's Avatar
Default Re: engine removal (crxstreetracer90)
block isn't that heavy but i would use a hoist or at least a rope from the ceiling. you might also be able to remove all the mounts and brackets and set the motor on the floor with a jack then lift the car over it and slide it out. that's how we got a sentra motor out of my friend's car, but i've never done it on a honda.
Old Jul 5, 2004 | 10:05 AM
5litereater's Avatar
Default Re: engine removal (mr. carpenter)
you could drop it thru the bottom. thats what i did.
Old Jul 5, 2004 | 10:42 AM
blah13's Avatar
Default Re: engine removal (5litereater)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5litereater &raquo;</TD></TR><TR><TD CLASS="quote">you could drop it thru the bottom. thats what i did.</TD></TR></TABLE>
Thats what I would do since you've removed the head. If you left the head on I'd pull it out the top.
Old Jul 5, 2004 | 10:46 AM
crx_88_si's Avatar
if you take it out the top dont forget to remove the shiftlinkage and axles.
Old Jul 5, 2004 | 11:12 AM
EFin' Kyle's Avatar
Default Re: (crx_88_si)
thank u for the replies i think i will try out the bottom
Jjeessee
Sep 14, 2015 11:55 AM
spooty
Sep 9, 2008 03:32 PM
HondaHero
May 18, 2007 08:05 PM
metal-x
Oct 22, 2002 10:48 AM
Integra91LS
Feb 19, 2002 09:01 AM
