APEXi WS2 exhaust flange hitting heat shield
Old Jul 5, 2004 | 05:18 AM
TouringAccord's Avatar
H-T Order of Merit
Default APEXi WS2 exhaust flange hitting heat shield
like the title says. I just installed my WS2 catback exhaust and one of the flanges are hitting the heat sheild thats under the feat area in the back seat. I was thinking of either bend the shield out of the way alittle or putting a piece of radiator house there to cut down or eliminate the vibration. It vibrates pretty bad while at idle and you can feel it a little when accelerating. If anyone else has had this problem what did you do to fix it? TIA
Old Jul 5, 2004 | 06:46 AM
jdmmugeneg6's Avatar
Default Re: APEXi WS2 exhaust flange hitting heat shield (TouringAccord)
I just installed my friends apex ws2 on his 99 civic coupe and he has the same rattle problem just at idle. Not sure what it is because I haven't had time to jump underneath the car, but it sure is annoying. I'll let you know if I figure anything out.
Old Jul 5, 2004 | 07:33 AM
WhiteDcGsr's Avatar
my ws2 exhuast only rattled when i would acclerate but then it would go away again i only had a test pipe and not a cat and installation in my eg was perfect nothing hit's each other
Old Jul 5, 2004 | 12:00 PM
H-T Order of Merit
Default Re: APEXi WS2 exhaust flange hitting heat shield (jdmmugeneg6)
On mine, the exhaust flange in the area below the back seat feet area is touching the driver side of the heat shield.
Should I bend the heat shield just enough to get it out of the way or should I put a piece of radiator house or other type of buffer to cut down on the vibration. Is there a down side to bending the heat shield? Would the radiator house handle the heat?
Any suggestions would be appreciated. Thanks
Old Jul 6, 2004 | 05:07 AM
H-T Order of Merit
anyone?
Old Jul 6, 2004 | 06:03 AM
moto27cm's Avatar
The WS/WS2 systems are a very tight fit. I just removed the heat sheilds all together. No problems at all.
Old Jul 6, 2004 | 06:19 AM
H-T Order of Merit
Default Re: APEXi WS2 exhaust flange hitting heat shield (moto27cm)
The car gets warm enough with no AC, I don't want to do anything that will add more heat. Thanks for the suggestion anyway. Any more ideas?
Old Jul 7, 2004 | 07:51 AM
H-T Order of Merit
any other suggestions?
Old Jul 7, 2004 | 07:59 AM
menkio's Avatar
pretty much awnsered your own question... just bend the hanger... or be slick and fab up some new mounts out of polyurthane
Old Jul 7, 2004 | 08:28 AM
H-T Order of Merit
Default Re: APEXi WS2 exhaust flange hitting heat shield (DewMota)
there no adverse affects from bend the heat shield out of the way? Not that I would be ebnding it that much but...
Old Jul 10, 2005 | 08:55 PM
loclowd's Avatar
Take your heat shield out all together...that's what I did on my 95 coupe. As long as your not going through any fields or anything, ur good
nicolaselias
Sep 29, 2010 08:24 PM
civic1234
Dec 23, 2006 10:43 PM
killaBc1
Mar 8, 2005 02:29 PM
dohcdelsol
Apr 8, 2004 12:31 PM
Civic89
Aug 24, 2002 05:33 PM
