Empty slots on ECU?
Old Jul 4, 2004 | 04:59 PM
sleeping beauty's Avatar
Default Empty slots on ECU?
I don't really want to tap another wire for the yellow/black wire from the IAB, so I need to know if there is a slot on the ECU that I can just plug in a wire to acheive the same goal cleanly.
If there isn't a way for me to do it that way, can I just tap into that big bundle of yellow/black wires on the driver's side tower harness?
Old Jul 4, 2004 | 05:17 PM
Turbogixxer's Avatar
Default Re: Empty slots on ECU? (sleeping beauty)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeping beauty &raquo;</TD></TR><TR><TD CLASS="quote">If there isn't a way for me to do it that way, can I just tap into that big bundle of yellow/black wires on the driver's side tower harness?</TD></TR></TABLE>
Sound like you have a EG. If so, yel/blk wires on the driver side tower is sensor voltage. That is what you need for the IAB (besides the pink wire that needs to go to a17 if OBD1 ECU), There should be a empty slot in that connector. Just solder a pinout on the IAB wire (take the rubber plug out of the empty slot) and plug it in. You have a factory look.
jdmsir4dr
Apr 25, 2013 08:33 PM
Monkey Fing a Coconut
May 28, 2005 06:58 PM
SAVIOVEGA
Sep 1, 2004 02:37 PM
Morhpeous
May 30, 2004 05:33 PM
B16Vtec
Aug 20, 2001 05:24 AM
