What is this hose? It dosen't exist in USDM motors.
Old Jul 4, 2004 | 11:52 AM
VWkila's Avatar
Default What is this hose? It dosen't exist in USDM motors.
This is a JDM B16a2. It's the thermostat housing and the hoses coming off it.
I can't find it's existance in any of the Helms manuals(Del Sol, Integra and Civic).
Actually, spare USDM thermostat housings that I have, where that hose is coming out, is blocked off.
Old Jul 4, 2004 | 11:54 AM
Luserkid's Avatar
Default Re: What is this hose? It dosen't exist in USDM motors. (VWkila)
No clue what its for but im thinking you could probably just cap it and be fine, but dont quote me on that
Old Jul 4, 2004 | 11:58 AM
VWkila's Avatar
Default Re: What is this hose? It dosen't exist in USDM motors. (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote"> but dont quote me on that
I won't.
Thanks for reading.
Old Jul 4, 2004 | 12:20 PM
.Beaver's Avatar
Bloody Beaver
I've seen JDM motors with oil coolers built in around the filter, maybe thats a line for the cooler?
Old Jul 4, 2004 | 12:28 PM
92b16vx's Avatar
I have it too on my EDM B16A2, goes up next to the bleed valve. Do you need one or what?
Old Jul 4, 2004 | 12:32 PM
B18C5-EH2's Avatar
Former Moderator
Loved
I'm honestly not sure, but does your engine have a fast idle valve attached to the bottom of your throttle body?
Is this from an OBD1 or OBD2 car?
Old Jul 4, 2004 | 12:37 PM
smart monkey's Avatar
that seems like a B16a first gen motor. I think that nipple is for the fist gen tbodies FITV valve that goes under the T body.
Old Jul 4, 2004 | 01:08 PM
VWkila's Avatar
Default Re: What is this hose? It dosen't exist in USDM motors. (smart monkey)
It's a second gen. B16
Old Jul 4, 2004 | 01:16 PM
Deemeetree's Avatar
Electrician
It might be for te blinker fluid to flow through. My guess...j/k.
If it's on the thermostat housing, definitely has to go to a location that coolant flows through. Look for diagrams, should help you.
Old Jul 4, 2004 | 01:23 PM
VWkila's Avatar
Default Re: (Dimi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimi &raquo;</TD></TR><TR><TD CLASS="quote">If it's on the thermostat housing, definitely has to go to a location that coolant flows through. Look for diagrams, should help you.</TD></TR></TABLE>
Well, the problem is, like I stated earlier. this passage does not exist in any of the Helms I own.
I was thinking just replace the thermostat housing with a USDM one.
Old Jul 4, 2004 | 01:26 PM
dogfood's Avatar
do you already have the necessary coolant hoses hooked up to your iacv. Judging by the size I would have said iacv. Are you running jdm manifolds and wiring harnesses? If not I would check for any spare hookups and if there weren't any I would swap out that housing for a usdm one.
Old Jul 4, 2004 | 01:31 PM
VWkila's Avatar
Default Re: What is this hose? It dosen't exist in USDM motors. (dogfood)
Isn't IACV connected to the intake manifold and not the thermostat?
PS: Actually, IACV has two hose coming off it, it has one going into the water connecting pipe(between water pump and thermostat housing) and one going to TB.
Old Jul 4, 2004 | 01:43 PM
VWkila's Avatar
Is this the fast idle control valve?
Old Jul 4, 2004 | 01:52 PM
VWkila's Avatar
I'm going to answer my own question: yes.
Right now, it's hooked up to the one intake manifold.
Old Jul 4, 2004 | 02:05 PM
hatchi's Avatar
is it possible that its from an automatic motor?? going to oil cooler in the radiator?
Old Jul 4, 2004 | 02:08 PM
VWkila's Avatar
Default Re: What is this hose? It dosen't exist in USDM motors. (hatchi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchi &raquo;</TD></TR><TR><TD CLASS="quote">is it possible that its from an automatic motor?? going to oil cooler in the radiator?</TD></TR></TABLE>
I think it is from a AT motor.
Old Jul 4, 2004 | 02:11 PM
Russ713's Avatar
dAng!
no
Old Jul 5, 2004 | 09:15 AM
dogfood's Avatar
I wasn't saying that, that IS the iacv, I was saying that connects to the iacv. And if it's an auto they are usually attached to the throttle body(3 pin). On a manual they are attached to the intake mani(2 pin).
Old Jul 5, 2004 | 10:02 AM
TwistedSI's Avatar
I'd be willing to bet it is for the oil cooler that goes under the oil filter in most ITR's and Japanese cars for that matter. And not just Honda's.
Old Jul 5, 2004 | 10:12 AM
zer0.'s Avatar
negative..my B16A is from an automatic motor and doesn't have that hose.
Old Jul 5, 2004 | 12:01 PM
B18EG6's Avatar
Default Re: What is this hose? It dosen't exist in USDM motors. (zer0_2_6ixty)
That hose on my GSR goes from that location, to the water neck that the upper radiator hose goes to, right near the bleed valve.
Little rough on where the bleed valve is on a b16
Old Jul 5, 2004 | 02:07 PM
VWkila's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zer0_2_6ixty &raquo;</TD></TR><TR><TD CLASS="quote">
negative..my B16A is from an automatic motor and doesn't have that hose.</TD></TR></TABLE>
Is your B16a first gen or second gen?
tinkertime
12
Aug 10, 2006 05:28 AM
UltimX
Feb 3, 2006 03:04 AM
i_HeArT_EgS
15
Jan 19, 2006 06:31 PM
1990hondaHF
Jul 29, 2005 09:22 PM
Honda Sport
May 5, 2005 06:52 AM
