What is this hose? It dosen't exist in USDM motors.
This is a JDM B16a2. It's the thermostat housing and the hoses coming off it.
I can't find it's existance in any of the Helms manuals(Del Sol, Integra and Civic).
Actually, spare USDM thermostat housings that I have, where that hose is coming out, is blocked off.
Re: What is this hose? It dosen't exist in USDM motors. (VWkila)
No clue what its for but im thinking you could probably just cap it and be fine, but dont quote me on that
Re: What is this hose? It dosen't exist in USDM motors. (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote"> but dont quote me on that
I won't.
Thanks for reading.
I won't.
Thanks for reading.
Former Moderator
I'm honestly not sure, but does your engine have a fast idle valve attached to the bottom of your throttle body?
Is this from an OBD1 or OBD2 car?
that seems like a B16a first gen motor. I think that nipple is for the fist gen tbodies FITV valve that goes under the T body.
Electrician
It might be for te blinker fluid to flow through. My guess...j/k.
If it's on the thermostat housing, definitely has to go to a location that coolant flows through. Look for diagrams, should help you.
Re: (Dimi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimi »</TD></TR><TR><TD CLASS="quote">If it's on the thermostat housing, definitely has to go to a location that coolant flows through. Look for diagrams, should help you.</TD></TR></TABLE>
Well, the problem is, like I stated earlier. this passage does not exist in any of the Helms I own.
I was thinking just replace the thermostat housing with a USDM one.
do you already have the necessary coolant hoses hooked up to your iacv. Judging by the size I would have said iacv. Are you running jdm manifolds and wiring harnesses? If not I would check for any spare hookups and if there weren't any I would swap out that housing for a usdm one.
Re: What is this hose? It dosen't exist in USDM motors. (dogfood)
Isn't IACV connected to the intake manifold and not the thermostat?
PS: Actually, IACV has two hose coming off it, it has one going into the water connecting pipe(between water pump and thermostat housing) and one going to TB.
I'm going to answer my own question: yes.
Right now, it's hooked up to the one intake manifold.
Re: What is this hose? It dosen't exist in USDM motors. (hatchi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchi »</TD></TR><TR><TD CLASS="quote">is it possible that its from an automatic motor?? going to oil cooler in the radiator?</TD></TR></TABLE>
I think it is from a AT motor.
dAng!
no
no
I wasn't saying that, that IS the iacv, I was saying that connects to the iacv. And if it's an auto they are usually attached to the throttle body(3 pin). On a manual they are attached to the intake mani(2 pin).
negative..my B16A is from an automatic motor and doesn't have that hose.
Re: What is this hose? It dosen't exist in USDM motors. (zer0_2_6ixty)
That hose on my GSR goes from that location, to the water neck that the upper radiator hose goes to, right near the bleed valve.
Little rough on where the bleed valve is on a b16
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zer0_2_6ixty »</TD></TR><TR><TD CLASS="quote">
negative..my B16A is from an automatic motor and doesn't have that hose.</TD></TR></TABLE>
Is your B16a first gen or second gen?
