camber kit vs control arms
Old Jul 4, 2004 | 09:01 AM
Maxboost808's Avatar
Default camber kit vs control arms
Is their a difference between camber kits and control arms? If so is one better to use than the other?
Old Jul 4, 2004 | 09:07 AM
antiJDM's Avatar
i've always used progress camber kits, they are not control arms, i've never used the control arms, but i've always liked something that stays in adjustment.
Old Jul 4, 2004 | 09:33 AM
North_Texas's Avatar
Default Re: (2thousandcivic)
Last time I checked I think Camber Kits and LCA's are different.
Old Jul 4, 2004 | 01:48 PM
antiJDM's Avatar
LOL do you know what an LCA is?
(lower control arm) people dont buy LCA camber kits, they buy UCA camber kits and pivot camber kits.
btw i read the original post wrong, i thought he was asking the difference between the two camber kits.
Old Jul 4, 2004 | 04:15 PM
WHAT TEH's Avatar
Right! For front suspension, there are 3 different camber correction kits. One is the adjustable upper control arm kits (ie: skunk2). Second is the set pivot kits (ie: ingalls). Third are the shorter control arms (ie: Suspension Techniques).
It's up to your preference on which is better. How often do you change the setup of your wheels or the ride height of your car? Go from that.
Old Jul 4, 2004 | 10:45 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2thousandcivic &raquo;</TD></TR><TR><TD CLASS="quote">LOL do you know what an LCA is?(lower control arm) people dont buy LCA camber kits, they buy UCA camber kits and pivot camber kits.
btw i read the original post wrong, i thought he was asking the difference between the two camber kits.</TD></TR></TABLE>
Yep, I wouldn't have posted it if I didn't. Anyways why don't you just get a Alignment instead of an Camber Kit. It's been proven and tested that Alignment is cheaper and works the same
Old Jul 4, 2004 | 11:51 PM
NineTwoSi's Avatar
Default Re: (DixieRedneck)
tell that to my bald *** tires....
Old Jul 5, 2004 | 07:00 PM
MAD B16's Avatar
Default Re: (I Am Jack)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Am Jack &raquo;</TD></TR><TR><TD CLASS="quote">tell that to my bald *** tires.... </TD></TR></TABLE>
I second that.
Old Jul 16, 2004 | 02:42 PM
WHAT TEH's Avatar
Default Re: (shatteredream69)
Isn't an alignment for toe-in/toe-out? You would still wear more on the insides of the tires.
Chemi421
Suspension & Brakes
11
Aug 30, 2017 04:25 PM
thumper64
Nov 8, 2009 02:46 PM
JDM KID 510
Suspension & Brakes
11
Aug 29, 2006 05:17 PM
