b16 headers with two bung.
Old Jul 3, 2004 | 02:15 PM
ironchef25's Avatar
Default b16 headers with two bung.
help me out guys. i thought i read about this header that dc have with two bungs already for obd-0 hmmmm but i cant seems to find that thread. if you guys know where to get them or you guys know that thread pls post up.thanks
Old Jul 3, 2004 | 02:44 PM
ironchef25's Avatar
Default Re: b16 headers with two bung. (ironchef25)
anyone??
Old Jul 3, 2004 | 02:48 PM
EL Vap133's Avatar
Nope, never seen DC make a header like that. I do know that Spoon makes a header with the 2 o2 bungs as well as a few other JDM manufacturers.
Old Jul 3, 2004 | 02:50 PM
ironchef25's Avatar
Default Re: b16 headers with two bung. (EL Vap133)
hmmmm i thought i read that somewhere...if i do get one where would i get a bung welded to. and how much would i end up paying..
Old Jul 3, 2004 | 02:51 PM
EL Vap133's Avatar
You can get it done at most exhaust shops, prices may vary.
Old Jul 3, 2004 | 03:19 PM
EFSiR's Avatar
doesn't hasport make this???
Old Jul 3, 2004 | 03:23 PM
EL Vap133's Avatar
Default Re: b16 headers with two bung. (EFSiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFSiR &raquo;</TD></TR><TR><TD CLASS="quote">doesn't hasport make this???
Ahh yes, I forgot they just came out with one. But I don't think I'll be buying one soon for $400.
Old Jul 3, 2004 | 06:28 PM
ironchef25's Avatar
ok so say i get a dc header and i ask them to weld a second bung where should i ask them to do weld it..
Old Jul 4, 2004 | 08:16 AM
doublethink's Avatar
i also need to know where....
can anyone post a pic?
Old Jul 4, 2004 | 08:24 AM
Jurassic Four's Avatar
From: Where you cant steal it, Maryland, United States
Default Re: b16 headers with two bung. (doublethink)
I had the same delima:
I have a 0bd-0 b16, with a DC header, and 1 bung. I just took the lazy way out and spliced the two sensors together. I had all the normall hesition problems, and running rich.
But, I have unplugged the O2 sensor(s) and, the PROM seems to be pretty accurate. No hesitaion, better gas milage, and no codes yet. I guess it just stays in open (closed? [I always get confused]) loop. But, I will report if a problem occurs.
Old Jul 4, 2004 | 12:28 PM
crxkane's Avatar
correct me if i am wrong, but dont most DC headers have the o2 bung at the end of the header for a odb1 car were the o2 sensor is right be for the cat. if you have a obd0 stock header then you can take it to most exhaust shops and have them weld 2 bungs in the same location as the stock ones. and then just close the one down by the cat.
Old Jul 10, 2004 | 10:01 PM
Magnum000's Avatar
Default Re: b16 headers with two bung. (crxkane)
you want to have 2 bungs welded on your header!!!! One on either the 1 or 3 and the other on the 4 or 2 exhaust tubes. You will have to block off the bung at the collector, it will not work with the JDM B16 ECU's!!!!!
Old Jul 11, 2004 | 12:50 AM
spaceman's Avatar
Default Re: b16 headers with two bung. (Magnum000)
go to hasport.com and check out the hybrid headers
Old Jul 11, 2004 | 03:52 AM
4gCRX's Avatar
I did the 4-wire O2 conversion and have no hesitation or richness.
juanchoenuncrx
Oct 17, 2007 09:05 AM
honda06si
15
Aug 16, 2004 05:30 PM
1QwIkEf
May 28, 2004 08:46 AM
GRAVEDIGGER
11
Aug 23, 2003 12:03 PM
SikofFalln
Nov 27, 2002 04:35 PM
