Rev up and Down.
90 Model civic the engine is d16a6.
I took another IAC valve off of another civic with the same motord 16a6 and it still does it.
I'm lost anything I am missing that I need to replace also. Do I need to adjust the throttle screw?
Any help will be greatly appriciated.
For me it wasnt that the vacum lines werent connected good, but that they werent connected properly. A few were switched around
Get a chart and make surere there all doen properly
Its probably the fast idle air control valve, its located under the throttle body. There is a right up on here about how to clean it out, basically inside there is a spring and a cap type thing, well it gets stuck open sometimes and you need to clean it.
sleepyeg6
Aug 27, 2005 02:29 PM
starbury
Apr 17, 2005 07:25 PM
