Getting new tires
Old Jul 2, 2004 | 03:49 PM
Mantis3024's Avatar
Default Getting new tires
Im planning on getting rid of these crappy stock tires and getting some decent ones. I've heard a lot of good things abotu the Kumho 712 so Im probebly getting that. My question is is it really worth it to change all 4 tires at the same time? Or should I just get them for the front 2 since its FWD?
Old Jul 2, 2004 | 04:21 PM
TunerN00b's Avatar
Default Re: Getting new tires (Mantis3024)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mantis3024 &raquo;</TD></TR><TR><TD CLASS="quote">Im planning on getting rid of these crappy stock tires and getting some decent ones. I've heard a lot of good things abotu the Kumho 712 so Im probebly getting that. My question is is it really worth it to change all 4 tires at the same time? Or should I just get them for the front 2 since its FWD?</TD></TR></TABLE>
I don't know about anyone else, but I would want them to match for several reason.
Looks.
Consistent feel from front to back. (different sidewalls ride differently)
Cornering.
Do you never rotate your tires?
I have friends who tried to auto-x on Kumhos, but ended up changing out for other tires. Also, if you're running stock rims, try using a set of 205/50-15s instead of the factory 195/55-15s, to get a little more tread on the pavement. Personally, I'd pick up a set of Falken's.
Old Jul 2, 2004 | 04:38 PM
The HamsterBall's Avatar
I don't think the Azenis last that long...
If you are going to get kumho's.. i'd try out a set of Kumho KH11's.. my friend had them on his 240SX and they were really good wet traction, with decent dry traction, and they lasted a hella long time (he drives hard too. no drifting mind you!)
Old Jul 2, 2004 | 04:47 PM
3.504's Avatar
Default Re: Getting new tires (The HamsterBall)
to be safe, you only need to replace in pairs. and always run the same size wheel diameter on the front, like if you pop a front tire, grab the spare, put it on the rear, and the rear actual wheel on the front. unless you're going short distance. a bunch of guys in auto-x i've heard run a skinnier rear tire for more nuetral handling characteristics
Old Jul 2, 2004 | 06:23 PM
IN VTEC's Avatar
If you're gonna get summer tires, get something better than the 712's.
Old Jul 2, 2004 | 06:55 PM
p nut's Avatar
I've had 712's for a year now, and I'm not that impressed. They're better than stock, but there are better choices. I'd look into the Kumho MX's, ES-100's, or the Azenies. Also, if you're on stock rims, I'd recommend going with the 195's instead of the 205's. With the Azenies, it might be ok, but with others, the steering is sloppy with the wider tires. Unless you've got 7" rims, stick with 195. I made the mistake of going 205 on my 6.5" Rota rims. It feels sooo sloppy going around corners now.
Also, change all four tires at once, not two at a time.
Silvertc
Sep 6, 2008 08:36 AM
L-Dawg
Honda Civic (2006 - 2015)
Oct 1, 2006 08:01 PM
JunIntegra
14
Mar 15, 2005 09:15 AM
SeOuLxK
Honda Motorcycles
32
Feb 24, 2005 08:10 PM
lke2drvgsr
Nov 11, 2003 06:54 PM
