how do i know which wiring harness to use on a b20/vtec swap???
hello, i was planning on doing a b20/vtec swap in my 96 acura integra. the set up was going to be a b16a head with a b20 block. but which wiring harness do i use. the b16a or b20?? and if you know where i could buy the harness from would be great. and with the head being obd1 and the block obd2 would this work and if so how would i make these obd's work???
PLEASE HELP ME!!!!
Modified by af1king1421 at 12:53 AM 7/2/2004
PLEASE HELP ME!!!!
use your factory car's harness. i believe obd1 and obd2 dist. clips are the same, not sure... correct me if i'm wrong anyone. if so... use your ls dist and saw the leg off and use your ls injectors unless you can get some obd1 pigtails, then use the b16 injectors. wire vtec solenoid, oil pres. safty switch, and knock sensor all outside the harness. get an obd2-obd1 jumper harness and use an obd1 vtec ecu. (chipped p28, obd1pr3, p30, p61, or if you have to p72)
my car was originally a ls but the head that i bought comes withe a b16a harness so do i still use the ls harness?? and do i still saw off the leg off the distributer??
what year is the car itself? does the b16 head come w/ a distributor? if it doesn't come w/ a dist., then you can use the LS dist. and saw the leg off. if it does come w/ a dist. it will have to be a matching obd dist.
the car is a 96 but wired for obd 1 and the head does come with a distributor. so do i use the b16a harness??
B18C1_CRX
Jul 15, 2006 03:35 PM
ShortbusEK
Jun 4, 2002 04:10 AM
