repinning engine harness plugs...
whenever I tried to repin engine harness plugs, I **** it up and yank the wire off the pin or something. I'm actually usually too lazy to even try it and end up lopping the plug off and hardwiring it anyone got any tips?
You can get a pin puller from snap-on to assist in your troubles...or you can get a very small flat head screw driver and push up on the clip and push the pin out.
good luck-Jason
good luck-Jason
buy, civic, connectors, crx, engine, harness, honda, hondacivic, main, plug, plugs, repin, repinengine, repinned, repinning
