B18A or B18B For Turbo???
Old Jul 1, 2004 | 06:06 PM
umrex's Avatar
Default B18A or B18B For Turbo???
im in a dilemma. which is better for boost. b18a is cheaper, but hard to find a low mileage one. b18b more expensive, but newer and more powerful. help me with a decision. remember this motor will be fully built (sleeves, pistons, rods, etc..)
Old Jul 1, 2004 | 06:14 PM
Rywire's Avatar
Default Re: B18A or B18B For Turbo??? (umrex)
I would get a b18a, unless you want obd1(b18b) might be nice.
Old Jul 1, 2004 | 07:19 PM
mR. Vash's Avatar
i dont know but i think my friend is selling his Ls B18a1 Longblock it has 106k miles on it. and hes from Northern Cali.
Old Jul 1, 2004 | 07:33 PM
Jester88Si's Avatar
they're basicly the same block only difference is in the head.
Old Jul 3, 2004 | 08:29 AM
Cain Marko's Avatar
Rotary Lift Specialist
Default Re: (Jester88Si)
how do you know if its obd1 or obd2???
Cain Marko's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by umrex &raquo;</TD></TR><TR><TD CLASS="quote">im in a dilemma. which is better for boost. b18a is cheaper, but hard to find a low mileage one. b18b more expensive, but newer and more powerful. help me with a decision. remember this motor will be fully built (sleeves, pistons, rods, etc..)</TD></TR></TABLE>
as for this, since the B18a is cheaper and your gonna rebuild everything anyway, just get the cheaper engine i guess
Old Jul 3, 2004 | 05:56 PM
michael O's Avatar
Default Re: (turtlecx92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turtlecx92 &raquo;</TD></TR><TR><TD CLASS="quote">how do you know if its obd1 or obd2???</TD></TR></TABLE>
b18a is from 90-91? integras which would make it obd1. 94-95?ls Integras would ablso be obd1. 96+ I believe are obd2. Someone correct me if I'm wrong. I always forget the years.
Old Jul 3, 2004 | 06:15 PM
BlueShadow's Avatar
If you are going to be building the motor up anyways, I would say go with the B18A. You can get one for a lot cheaper, and mileage wont really matter too much because as you said it will be built. And what you said about the B18B having more power also shouldn't matter too much, because you're gonna be boosting the motor anyways. Another added advantage of the B18A is if you use the stock cable tranny, it will drop in a lot easier, and a lot cheaper (no cable-to-hydro conversion neded).
Old Jul 3, 2004 | 06:19 PM
BlueShadow's Avatar
Default Re: (michaelOlson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by michaelOlson &raquo;</TD></TR><TR><TD CLASS="quote">b18a is from 90-91? integras which would make it obd1. 94-95?ls Integras would ablso be obd1. 96+ I believe are obd2. Someone correct me if I'm wrong. I always forget the years.</TD></TR></TABLE>
I thought that 91 and below was OBD 0 aka. non-OBD, 92-95 was OBD 1, and 96+ was OBD 2+? I'm almost sure that's the years for the different OBDs.
EDIT: here is a site that lists the diff OBD's, so It looks like 91 below are non-OBD, but 92-93 B18A's are OBD 1.
http://www.frogenginecontrols.com/OBDGen.html
Old Jul 3, 2004 | 07:50 PM
Jester88Si's Avatar
Default Re: (BlueShadow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueShadow &raquo;</TD></TR><TR><TD CLASS="quote">
http://www.frogenginecontrols.com/OBDGen.html</TD></TR></TABLE>
thats correct....
Old Jul 27, 2004 | 08:15 PM
lococoin's Avatar
you can usually find cheap b18a1's from a 92 or 93 ls, gs, rs and they are obd1
Old Jul 27, 2004 | 09:28 PM
ThatRicerDaniel's Avatar
Default Re: (lococoin)
I have a b18b freshly rebuilt with OEM parts in ncal you can buy for cheap. there is low compression in cly 3, im thinkin one of the rings is messed up. good for rebuild.
Old Jul 28, 2004 | 05:38 PM
B18Tahtaras's Avatar
92-93 b18a's are obd1, and also they are rated at 140hp unlike the 90-91's that were rated at 130hp
methodz55
13
Apr 11, 2006 07:15 AM
H22CL
Sep 22, 2004 05:45 PM
tgintegra
Dec 20, 2003 01:21 PM
SupaFly_Honda
Dec 19, 2002 05:38 PM
Adampops
Jan 9, 2002 01:30 PM
