well the turbo built LS died, lsvtec turbo now, but, what turbo...
Old Jul 1, 2004 | 08:42 AM
wade's Avatar
Default well the turbo built LS died, lsvtec turbo now, but, what turbo...
i had a b18a with JE 9.1 pistons, bored .20 over, arp rod bolts, arp head studs, eagle rods, Hondata s200b and more and the other nite i bent a valve and screwed a piston ring.
Sooo, i sold the LS head and intake manifold and bought a B16a head. so now i am a LSvtec turbo...but i am wating for the head in the mail to install. what turbo is good to replace my beat up t3t4 with? my rev limit will be 8100RPM
Old Jul 1, 2004 | 08:54 AM
troubledsol03's Avatar
Default Re: well the turbo built LS died, lsvtec turbo now, but, what turbo... (wade)
I am running a t3 60-1 and i love it on my ls vtec it is being tuned as we speak
Old Jul 1, 2004 | 09:06 AM
System-7's Avatar
me too also a gt35killer by Innovative(t60-1). built ls/vtec 9:0 compression 317whp @ 9psi.
Old Jul 1, 2004 | 09:10 AM
wade's Avatar
Default Re: (System-7)
a gt35killer is a t3 60-1? what rpm do u all get full boost? whats ur rev limits?
Old Jul 1, 2004 | 09:11 AM
Turbocivic94's Avatar
Default Re: (wade)
I have Innovative T3/60-1 on my lsvtec and loving it
Old Jul 1, 2004 | 09:13 AM
wade's Avatar
Default Re: (Turbocivic94)
ok u all got the same turbo, what size wheel and AR u all got?
Old Jul 1, 2004 | 09:14 AM
Rod.'s Avatar
i have a sc61 im going to use on my ls/vtec
how did you bend a valve?
Old Jul 1, 2004 | 10:18 AM
wade's Avatar
Default Re: (redturbocivic)
i think its cuz i needed tuned bad and my car was lean uptop always and i hammered a little to hard and looked like a valve that was bent was also white, telling me SUPER HOT TEMP! so when metal gets super hot, it warps and bends easy, so figure
Old Jul 1, 2004 | 10:33 AM
Default Re: (wade)
.63 A/R STG V
Old Jul 1, 2004 | 10:36 AM
wade's Avatar
how does it spool, what rpm at full boost
Old Jul 1, 2004 | 12:00 PM
Default Re: (wade)
I like it cause I dont like boost low down. full boost by 5200
plus I rev my motor to 9K
Old Jul 1, 2004 | 12:31 PM
wade's Avatar
would that turbo b worth it if u rev to 8100
Old Jul 1, 2004 | 02:08 PM
chad174's Avatar
Default Re: (wade)
I don't think so. You should get something where you're spooled at around 4k.
Old Jul 1, 2004 | 04:03 PM
NVturbo's Avatar
O.G. triple O.G.
PRECISION SC61....with .63 A/R trim!!!
Old Jul 1, 2004 | 04:22 PM
94gsr4dr's Avatar
Default Re: well the turbo built LS died, lsvtec turbo now, but, what turbo... (NVturbo)
t3/67
Old Jul 1, 2004 | 04:25 PM
Chip's Avatar
Default Re: well the turbo built LS died, lsvtec turbo now, but, what turbo... (94gsr4dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94gsr4dr &raquo;</TD></TR><TR><TD CLASS="quote">t3/67</TD></TR></TABLE>
What is with everyone on here wanting to overturbo? He has a stock sleeve LS/VTEC that he is going to rev to 8000 RPM's tops. HE DOESN'T NEED A 600+ WHEEL HORSEPOWER CAPABLE TURBO!!!
Old Jul 2, 2004 | 01:59 PM
D-booster's Avatar
Default Re: well the turbo built LS died, lsvtec turbo now, but, what turbo... (Chip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chip &raquo;</TD></TR><TR><TD CLASS="quote">
What is with everyone on here wanting to overturbo? He has a stock sleeve LS/VTEC that he is going to rev to 8000 RPM's tops. HE DOESN'T NEED A 600+ WHEEL HORSEPOWER CAPABLE TURBO!!!</TD></TR></TABLE>
I'm with you on that
Old Jul 2, 2004 | 07:51 PM
Default Re: well the turbo built LS died, lsvtec turbo now, but, what turbo... (D-booster)
T3/T4E would work fine for u or just get SC61
Old Jul 2, 2004 | 11:12 PM
ojoemamao4o's Avatar
Default Re: well the turbo built LS died, lsvtec turbo now, but, what turbo... (Turbocivic94)
im going lsvtec turbo with a gsr head insetad of b16...when i go turbo, what kit do i buy it for, the LS or the GSR
Old Jul 6, 2004 | 01:32 PM
Default Re: well the turbo built LS died, lsvtec turbo now, but, what turbo... (ojoemamao4o)
It depends on ur intake manifold. If u r using gsr manifold u would have to buy for GSR. If using skunk2 manifold u would have to buy it for LS
Old Jul 6, 2004 | 02:18 PM
PrecisionH23a's Avatar
https://honda-tech.com/zerothread?id=906436
1lsvtecturbo1
Feb 22, 2009 10:55 AM
Fastjato33
Feb 19, 2009 02:38 PM
JDMJunior
Jul 24, 2006 06:53 AM
allmotor_dm
Jan 13, 2006 08:57 PM
gliaw
Jan 17, 2003 09:11 PM
