ls motor ticking noise
i am hearing a ticking sound coming from my motor, what could be the problem, its an ls motor with stage 1 cams and bolt ons ,any help would be appreciated, o yea and i have
stock vualve train
stock vualve train
have your valves been adjusted recently?? if not it may be time to do so. Other thing that ticks is your fuel injectors, but I don't know how loud. A lot of people say that b-series have a loud valvetrain anyway. But I'd definitely think about the valve adjustment.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ctegsta »</TD></TR><TR><TD CLASS="quote">it seems as though there are two noises one from the cams and the other from somwhere else and the motor vibrates as well</TD></TR></TABLE>
somewhere else huh? humm... I think it's..... ohhhh myyyyy goddddd... It's... it's... IT'S A BOMB!
ok, ok... enough with the bombs... if it's a valve adjustment, you should do it as soon as possible because there is too much lash and the lifters are essentially beating up against the valve which can cause premature wear or worse...
IT COULD BE A BOMB!!!!
As far as the other place, take a long screw driver, or a mechanics stethascope, and put the handle tight against your ear, and put the tip of the screw driver against each component, Alt, valve cover, air con. comp, etc, this is the best way to locate an annoying tick (could be a bearing) but I would FIRST recomment since you know that the valves are out of adj, get that taken care of... If you have a feeler gauge and a little experiance you may be able to do it yourself. make sure you replace your valve cover gasket, if you do take it in, make sure you don't get hosed! post your estimate on here and ppl will let you know if it's a good price.. It's a fairly simple job, assuming nothing needs to be replaced, and honda's are natorious for ticking and have adjustable valvetrains for this exact reason.. eitherway, make sure your face is AWAY from the valves when you remove the valve cover gasket in the event that it is indeed......
A BOMB!!!!
A BOMB!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Medek »</TD></TR><TR><TD CLASS="quote">may not help you... but are you running less then 91-92 octane? my ls ticked (i swear) when i ran 87 for a couple months. went away after switching.</TD></TR></TABLE>
i thought the same thing, i used to use 93 cause it wasnt that much more expensive here [awhile ago] but since i've switched back to 87 and heard the ticking...but i probably just never noticed it before
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elementmilwaukee »</TD></TR><TR><TD CLASS="quote">ohh god, this pood noob thinks that were all *********** on h-t.. it's not usually this bad dude.. </TD></TR></TABLE>
You are the only Chickensucker here, Sir.
ewwww......i've never put anything lower than 93 in mine and i got some bad 93 oct gas once and i had a tick and it went away after i filled up again, my car must be really sensative or something!..... but i knew it wasnt the valves bc i had just got them adjusted!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall »</TD></TR><TR><TD CLASS="quote">All B series motors tick a little bit, but it's very possible that you need a valve adjustment after the cam install.</TD></TR></TABLE>
Yeap. ALL B-Series motor tick, so you shouldn't worry TOO much. Do a valve adjustment afterwards and it should be a bit quieter... but the ticking should still be there. Don't sweat it. If the car is running normal and idle's smoothly, it should be all good.
i almost forget.. my old b21, d16, (and whatever was in my 86 accord), plus my b18.. all ticked generally after a couple thousand miles after an oil change. fresh oil and filter always eliminated the tick.
slow_cx
May 11, 2008 11:50 AM
g2style
Feb 5, 2003 01:57 PM
