what the producere for adjust valve on a d16a6
Old Jun 30, 2004 | 07:37 PM
4DRmafia's Avatar
Default what the producere for adjust valve on a d16a6
this will be my first time so do i used the feeler gauge on the cam shaft or ? i really dont know how to do this stuff
Old Jun 30, 2004 | 07:41 PM
4DRmafia's Avatar
and yes i did use the search button but it was very helpful for a 1st timer
Old Jun 30, 2004 | 07:54 PM
4DRmafia's Avatar
is the spec for the feeler gauge is .017 to .022 do i put them together for the cam lobe clearance ? or the vavle rocker arms
Old Jun 30, 2004 | 09:24 PM
4DRmafia's Avatar
bumpty bump i wanna do this tmw
Old Jun 30, 2004 | 09:49 PM
EG8R's Avatar
Default Re: (SkipMic2006)
Remove valve cover
Set to TDC
Adjust loose rockers
Turn 180 degrees
Adjust ones you didn't adjust before
Put on valve cover
Old Jun 30, 2004 | 10:26 PM
4DRmafia's Avatar
where do i adjust it from ,using the feeler gauge on the cam lobe between the lobe and the rocker arm or what? what the spec
Old Jun 30, 2004 | 10:38 PM
Curtis2kul's Avatar
free bump im pretty sure its where the rocker arms meet the valve spring
Old Jun 30, 2004 | 10:46 PM
4DRmafia's Avatar
totally lost how on doing this lol
Old Jun 30, 2004 | 10:51 PM
4DRmafia's Avatar
what does they mean by .017to.022 mean the feeler gauage go together between 17 to 22? and where did u get this infomation from ?
Old Jun 30, 2004 | 10:52 PM
Traction's Avatar
dont tell me you searched, because I made a thread just this week on how to adjust d series valves and I got a good 50 posts in there and there is a huge one in the Eg forum that is ongoing on adjusting d series valves.
If you dont knwo what your doing, just go pay to have it done or ask a buddy/uncle whatever to show you, you can **** up a lot
Old Jun 30, 2004 | 11:05 PM
4DRmafia's Avatar
could u showe me the post u made ? pls so i can read it up see if i understand it
Old Jul 1, 2004 | 06:32 AM
manson's Avatar
buy a haynes manual. detailed instructions on how to do anything to your vehicle for $19.99 and above.
Old Jul 1, 2004 | 07:10 AM
senpai's Avatar
Default Re: (manson)
https://honda-tech.com/zerothread?id=905873
Old Jul 1, 2004 | 09:11 AM
blah13's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkipMic2006 &raquo;</TD></TR><TR><TD CLASS="quote">what does they mean by .017to.022 mean the feeler gauage go together between 17 to 22? and where did u get this infomation from ?</TD></TR></TABLE>
You really should have someone else do this. If you couldnt understand the page he posted your kinda fubared on this...17-.22mm is the width of feeler gauge you need to use. Then look at the pic, it shows you where to put the gauge.
Old Jul 13, 2004 | 08:28 PM
4DRmafia's Avatar
so i got to the point on how to do it , so my question is 0.17-.022 is the width i have to use ?
Old Jul 13, 2004 | 10:33 PM
4DRmafia's Avatar
aww u guys gonna let my car sit ......cries*
Old Jul 14, 2004 | 04:23 AM
TiggsCRX's Avatar
yes, .17 to .22 mm or .007- .009in. just find your feeler gauge, use a size in between, such as .008 in or .20mm. good middle of the road. These numbers just mean that they can be as loose as .22mm(.009in) and as tight as .17mm(.007in)
Remember, that's for the intake side
the exhaust side is .22-.27mm(.009-.011in) so use something in the middle of the road like .25mm or .010in
Follow the instructions, it's very simple.
just loosen the lock with a 10mm, hold the loose nut in place, with a flathead screwdriver, turn the screw to make it more tight or more loose until you can slide the feeler gauge in and out with slight drag, then while holding the screw in place with a screwdriver, tighten the 10mm bolt. do that for each one. should be simple. You'll be amazed at the simplicity after you do your first one.
don't forget to line up the timing marks as listed. there's a second page to that helms page that shows where the timing marks should be and for which cyl to adjust. I don't have the time to find it but if you do a good thorough search (including archives!) I'm sure you can find it. Check the FAQ section at the top of the crx forum, i think it might be in there.
Old Jul 14, 2004 | 07:00 AM
Dwight Schrute's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by manson &raquo;</TD></TR><TR><TD CLASS="quote">buy a haynes manual. detailed instructions on how to do anything to your vehicle for $19.99 and above.</TD></TR></TABLE>
btw haynes sucks. helms all the way
Old Jul 14, 2004 | 07:53 AM
hondacivic_si's Avatar
Default Re: (drewthomas14)
Hey now, I love my haynes Manual, its very helpfull for nOOb's like me
Old Jul 14, 2004 | 01:44 PM
4DRmafia's Avatar
i got the haynes book lol
Old Jul 14, 2004 | 01:46 PM
4DRmafia's Avatar
hey well i ticks just a lil now can i drive it like that ? until i find some 1 to do it for me
Old Jan 23, 2005 | 05:43 PM
thrty8street's Avatar
what is the PISTON order?
Old Jan 23, 2005 | 05:57 PM
88 rex's Avatar
Default Re: (thrty8street)
Pic is in the sticky at the top of the page for piston order..........or in the pic provided in this thread, or you could pull the spark plug and just find out what TDC center is with something like a screwdriver.
Old Jan 23, 2005 | 06:10 PM
90LSpimpin's Avatar
Default Re: (88 rex)
Piston order is firing order. 1-3-4-2.
Easy way to tell when ur at the right spot other than the fist cylinder when ur at TDC, is pull spark plugs, put long screwdriver in hole of cyl ur doin, move crank and watch for the screwdriver to be at its top most point for that cylinder in the firing order. Valve adjustment is childs play. Its hard the first time cus ur new, after that its a breeze.
HatchSpeeD
Jul 5, 2005 01:29 PM
4DRmafia
16
Aug 22, 2004 07:51 PM
ORcivicsi
Jul 17, 2004 12:37 PM
White Lightnin
Mar 10, 2003 09:30 AM
FitCRX
Jan 21, 2003 01:21 AM
