an idea I have, using duct work heat tape on charge pipes..
I was in a friends truck the other day who is a hvac installer.. I saw a roll of alumium sided tape that he said that they use on duct work when its near a heat source to block heat from entering the duct work..
What about putting this stuff on the charge pipes that are near the turbo and other heat sources.. Hes anyone tried this or have an comments about it..
sounds like a great idea
on my 14B the outlet off the turbo is veryyyyy close to the manifold (1/4 in)
i would love some of that
I know what im doing tonight..
My charges pipes that are right near the turbo are very hot, almost too hot to touch.. Im gonna get some of this stuff from my friend and ill let you know how much it changes the intake temps..
I'm not sure how well the aluminum tape is going to work for you. It's made for construction use, like maybe 130 degrees. I don't think the adhesive is going to hold up well to the heat of the engine, as in it might melt or give off fumes. You can try it out though.
Its better to have the charge piping uncovered, and/or unpainted.
If you cover up the charge piping, all your doing is traping radiant heat inside. The covering will not keep the heat from penetrating, but it will keep it from escaping (just like wearing a jacket).
This is why aluminum charge piping is best, because it will radiate the most heat.
Hmm.. Interesting.. Never though of that.. Maybe a better idea then would be to build an aluminium shield around the charge pipe so that heat would be rejected from it but the pipe could still radiate heat from inside..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves »</TD></TR><TR><TD CLASS="quote">Hmm.. Interesting.. Never though of that.. Maybe a better idea then would be to build an aluminium shield around the charge pipe so that heat would be rejected from it but the pipe could still radiate heat from inside..</TD></TR></TABLE>
That exactly it.
Just like the factory heatsheilds... the best thing to have is a space between the piping (or whatever your trying to protect) and the heatsheild. This way the shield ends up absorbing most of the heat, and radiates it before it can get to the piping.
That exactly it.
Hmm.. Ill have to think about how I can build a "heatshield" for my chargepipes.. Doesnt seem that hard but still requires some though so it doesnt look like total ****..
I don't know if you have enough room to do this...but the easiest way to go about doing soemthing like that, is get some tubing (aluminum is prefered of course) that is bit larger than your IC piping, and cut the tube in half down the center. Then attach half of the tube to the pipe with a braket of some sorts.
Just something to think about...
CarbonCreations
Welding / Fabrication
Nov 11, 2005 07:45 AM
stealthteg
Apr 18, 2002 11:30 AM
