prothane inserts- which mounts are they for??
Old Jun 30, 2004 | 10:45 AM
blackeg's Avatar
Default prothane inserts- which mounts are they for??
hello all, the front lower drivers side mount on my 93 ex(the one thats right below the power steering and attatches to the front of the block) is all ripped and broken. now that im boosted, i need to get that **** fixed. i was looking into the prothane inserts, but im not sure if they are for that lower mount? anyone have info on this for me??
Old Jun 30, 2004 | 11:45 AM
blackeg's Avatar
Default Re: prothane inserts- which mounts are they for?? (blackeg)
ttt
Old Jun 30, 2004 | 11:50 AM
Adam.'s Avatar
The inserts aren't necessarily made to fix a broken mount, they are supposed to fill up the space around the stock floating mount. You replace the mount with a stock one and then put in inserts or find a solid polyurethane aftermarket replacement.
Old Jun 30, 2004 | 07:21 PM
blackeg's Avatar
Default Re: prothane inserts- which mounts are they for?? (DarkKnight[DMD])
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkKnight[DMD &raquo;</TD></TR><TR><TD CLASS="quote">]The inserts aren't necessarily made to fix a broken mount, they are supposed to fill up the space around the stock floating mount. You replace the mount with a stock one and then put in inserts or find a solid polyurethane aftermarket replacement.</TD></TR></TABLE>
true. im gonna say that all inserts are like this then. i wonder if i should just use window weld
TypeRod
Dec 7, 2011 02:45 PM
JDM_Risa
Apr 11, 2006 05:08 PM
Liquidgsr
Nov 10, 2005 10:58 PM
SwissChEz82
Nov 17, 2004 10:20 AM
Loveless
Oct 14, 2003 09:52 AM
