For you enine builders: Valve to Piston clearance?
Old Jun 30, 2004 | 06:47 AM
fortynineR's Avatar
Default For you enine builders: Valve to Piston clearance?
Im in the process of claying my motor for valve- piston clearances. my head is milled about 35-40k i am using 12.5 arias pistons and Jun3s. P-v clearance is fine when the cam gears are at 0 in and 0 ex. I do not have valve-valve clearance at 0 in and 0 ex, so i need to either advance the ex. by 2 or retard the in. by -2 to get a valve to valve clearance of .030. Since my head is milled I do not want to guesstimate TDC until i get it to the dyno. My question is... Since my set up clears 0,0 (but i need to run +2 ex or -2 in for valve to valve clearanc) will advancing the intake cam or retarding the intake cam give me more piston to valve clearance?
Any comments, suggestions, or info will be greatly appreciated.
Old Jun 30, 2004 | 08:29 AM
93H22ACX's Avatar
Default Re: For you enine builders: Valve to Piston clearance? (fortynineR)
let me know when you find out too
Old Jun 30, 2004 | 08:37 AM
zad5's Avatar
here is my guess -2 intake -2 exhaust will give the most clearance and you should clay with +2intake and +2 exhaust just to make sure.
96halx
Jul 25, 2009 11:09 AM
Fei
11
Jul 28, 2008 12:21 AM
d-series-buildup
19
Dec 19, 2007 10:23 AM
1 2 NV
12
Jun 11, 2006 04:03 PM
95gsr
Apr 8, 2003 07:20 AM
