clutch problems, clutch pedal won't come up
Old Jun 30, 2004 | 06:19 AM
FLCivic's Avatar
Default clutch problems, clutch pedal won't come up
This is on a B18C motor, anyways I was at a stoplight with the clutch pedal depressed and as I was about to go the clutch was stuck to the floor. I had to reach down and pull it back up. Otherwise I have no other problems with it. If I quickly step on the clutch and let go the pedal will come up, but if I keep the clutch pedal down for awhile like at a stoplight the pedal stays close to the floor and I have to manually pull it back up. What's up with this??
Old Jun 30, 2004 | 06:23 AM
Filthy Focker!'s Avatar
Default Re: clutch problems, clutch pedal won't come up (FLCivic)
Does your car come with an hydraulic clutch?
fs
Old Jun 30, 2004 | 06:46 AM
Deemeetree's Avatar
Electrician
If you're car is 1992 or newer, bleed your clutch system. You might have air in the lines. How is the fluid level on the Clutch Master Cylinder resevoir? Is it low? Check for leaks (especially on the Clutch Master Cylinder. Look inside your car, where the Clutch Master Cylinder "rod" goes through the firewall. Do you see any leaks or buildup of oil?).
Old Jun 30, 2004 | 10:59 AM
93CivicSI's Avatar
Clutch master cylinder or slave cylinder may be going bad.... - as others have said - blled the system first...
Old Jun 30, 2004 | 11:25 AM
Ignitecivic's Avatar
Default Re: clutch problems, clutch pedal won't come up (93CivicSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimi &raquo;</TD></TR><TR><TD CLASS="quote">If you're car is 1992 or newer, bleed your clutch system. You might have air in the lines. How is the fluid level on the Clutch Master Cylinder resevoir? Is it low? Check for leaks (especially on the Clutch Master Cylinder. Look inside your car, where the Clutch Master Cylinder "rod" goes through the firewall. Do you see any leaks or buildup of oil?). </TD></TR></TABLE>
yeah u need to bleed it, but if it keeps on happening most likely ur <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CivicSI &raquo;</TD></TR><TR><TD CLASS="quote">Clutch master cylinder or slave cylinder may be going bad.... - as others have said - blled the system first...</TD></TR></TABLE>
Old Jun 30, 2004 | 03:48 PM
FLCivic's Avatar
Default Re: clutch problems, clutch pedal won't come up (Ignitecivic)
Thanks for all the replies, I checked the clutch master cylinder and it was empty!! So most likely I'll have to bleed the whole system and check for leaks. Thanks again.
PaulMc
May 18, 2014 05:04 PM
hannslebo
Mar 24, 2009 01:53 PM
s1ngle
13
Sep 21, 2005 12:01 PM
DriveSideWays
Aug 27, 2004 05:06 PM
g00se
Mar 8, 2004 06:11 PM
