please help with vtec
Forget about the obd0 and the ecu.. If you send 12 volts to the vtec noid it will turn on.. The vafc will send 12 volts to it when you tell it to..
You could use the vafc's vtec output to turn on your head lights on your lawnmower if you wanted to.. Its just a rpm dependant 12 volt output..
Single wire one.. the other plug is the vtec pressure sensor which you dont need.. With the engine off run a wire from the + side of your battery to the single wire connector and youll hear it click.. thats the noid turning on..
ilovemyb16a
May 18, 2006 12:58 PM
05 S2K Stoner
Oct 28, 2004 06:40 AM
Frederz
Feb 29, 2004 10:01 PM
Turbo Powa
14
Apr 8, 2003 08:48 AM
