98 GSR ECU code 61 thrown: Primary O2 Sensor
Old Jun 29, 2004 | 08:34 AM
Lewie's Avatar
I'm here for the gangbang!
Default 98 GSR ECU code 61 thrown: Primary O2 Sensor
I found out that my CEL light is on b/c code 61 is being thrown. It's the Primary Oxygen Sensor. What could be causing it? A bad o2 sensor, or could the o2 sensor not be put back in when I had my header installed?
Old Jun 29, 2004 | 09:05 AM
deSigi's Avatar
Default Re: 98 GSR ECU code 61 thrown: Primary O2 Sensor (HSPLewie)
It's an actual malfunction with the O2 sensor. If it wasn't connected properly, it would be throwing a code 65.
Old Jun 29, 2004 | 09:12 AM
Lewie's Avatar
Default Re: 98 GSR ECU code 61 thrown: Primary O2 Sensor (e-kay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e-kay &raquo;</TD></TR><TR><TD CLASS="quote">It's an actual malfunction with the O2 sensor. If it wasn't connected properly, it would be throwing a code 65.</TD></TR></TABLE>
Thanks for the help. Now I have to go check the sensor. Thanks again.
Old Jun 30, 2004 | 11:33 AM
deSigi's Avatar
Correction it wouldn't be code 65 it would be code 41. Got 1st and 2nd O2 sensors mixed up.
924drb20
Dec 14, 2010 10:36 AM
importnoodles
Mar 29, 2008 10:20 AM
slim689
Apr 19, 2007 10:55 AM
s14hybrid
Nov 24, 2004 05:16 AM
