Car runs terrible at 7psi - need help please
Hallo,
i need an advise from someone who has some know-how in tuning a boosted engine.
my setup: Stock B16A1 Engine 10:1 Compression ratio.
Garret T3 with 7-8psi boost.
Standalone ECU.
my AFR is ~14,7:1 until 800mbar (absolute), from 0-3psi i have ~13:1 and from 3psi on until 6psi i have ~12:1
over 6psi i'am a bit rich at the moment AFR is aprox. 10:1 to 11:1.
if i rev over aprox. 5000rpm (Vtec is active) and go over 7psi the car starts bogging.
i think it is no knocking but i have no power at this moment.
ignition is stock with 0,75° per psi retard so i have aprox 18° ignition advance in this area.
Can someone tell me why my car boggs in this conditions and what do i have to do to prevent this?
Thanks
Malte.
Standalone ECU.
Thanks
Malte.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MachAF »</TD></TR><TR><TD CLASS="quote">Tune that 10:1 ratio to 12:1. Too much fuel is causing the bogging.</TD></TR></TABLE>
Ok, i have now 12:1 and its a lot better... but only one problem left.
when vtec kicks in (5000-6000rpm) the car boggs also a littlebit fast after each other, hard to describe. but only in the first 2 gears and ONLY unter full throttle.
what can that be?
same somes up later at aprox: 7000rpm but not always.
Thanks
Malte.
what can that be?
Thanks
Malte.
T--Rex
Jun 29, 2005 08:32 PM
SpoolinSol
Apr 15, 2002 10:46 AM
