does the gsr have oil pressure sensor ?????
does it have the oil pressure sensor on the back of the block by the oil filter? the dx harness has two wires that have a big black boot over the end on them.... can't find where to plug this in on the gsr motor...
Are those two wires on the dx harness under the boot black and yellow? If so, those are the coolant temp sensor wires. The oil pressure wire should be a similar wire, but under a smaller boot. It's just to the left of the oil filter on my B18C1.
The coolant temp sensor is on the thermostat housing on the newer motors instead of the back of the block like on the older CRX engines.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr_CRX »</TD></TR><TR><TD CLASS="quote">
The coolant temp sensor is on the thermostat housing on the newer motors instead of the back of the block like on the older CRX engines.</TD></TR></TABLE>
awesome, thats what i was looking for...thanks
kreatekustomz
Sep 30, 2009 11:50 AM
h22_crx
Jan 19, 2007 03:06 PM
