Can JB Weld hold on a block?
Old Jun 28, 2004 | 03:54 PM
dunkd's Avatar
Default Can JB Weld hold on a block?
I have a small pin sized hole in the back of my block. i believe its from an error in the casting, and when it was hot tanked it made it come out....
a builder around here told me that jb weld wont hold on a block bc it will heat up and expand causing the jb weld to crack off...
Old Jun 28, 2004 | 03:56 PM
Kendall's Avatar
I've seen JB Weld hold well enough on a block, however I'd use some of that aluminum epoxy instead.
Old Jun 28, 2004 | 06:34 PM
BigMoose's Avatar
Default Re: Can JB Weld hold on a block? (feri0)
My personal preference would be to drain the radiator, clean the surface thoroughly with acetone, roughen the surface with an abrasive if you can get at it, clean again with acetone, pull a slight vacuum on the cooling system to get the epoxy to flow a little into the porosity and use Devcon aluminum filled industrial epoxie #10610, in particular:
http://www.devcon.com/devconfa...id=15
Old Jun 28, 2004 | 06:59 PM
b18bEG's Avatar
buddy of mine used JB weld.... it worked for a little bit of time, then he had to do it over and over and over again
Old Jun 28, 2004 | 07:01 PM
dunkd's Avatar
Default Re: (b18bEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bEG &raquo;</TD></TR><TR><TD CLASS="quote">buddy of mine used JB weld.... it worked for a little bit of time, then he had to do it over and over and over again</TD></TR></TABLE>
how bad was his crack/hole?
Old Jun 28, 2004 | 08:48 PM
Sack Master's Avatar
Default Re: (feri0)
Just don't use JB weld. It will more then likely give you problems down the road.
Old Jun 28, 2004 | 10:07 PM
murtnabila's Avatar
Default Re: (Sack Master)
jb weld don't hold on a motor, will give u more problems then solutions.
Old Jun 29, 2004 | 08:01 AM
b18bEG's Avatar
Default Re: (feri0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by feri0 &raquo;</TD></TR><TR><TD CLASS="quote">how bad was his crack/hole?</TD></TR></TABLE>
it was small at first, then it got progressively bigger
Old Jun 29, 2004 | 09:25 AM
dunkd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sack Master &raquo;</TD></TR><TR><TD CLASS="quote">Just don't use JB weld. It will more then likely give you problems down the road.</TD></TR></TABLE>
what is ur advise? aluminum epoxy?
Old Jun 29, 2004 | 10:05 AM
92HatchHybrid's Avatar
you will have to go over it and over and over.... it will hold but keep breakin off..
mike
Old Jun 29, 2004 | 10:23 AM
Sliced Beard's Avatar
Default Re: (92HatchHybrid)
i say do it right, get it welded closed
just find a Awning shop or some company that has a MIG aluminum welding machine and just spot weld it closed. If you spot weld it and let it cool inbetween blasts of heat you will have absolutely no problems.
Old Jun 29, 2004 | 11:16 AM
f u z z's Avatar
Default Re: (dirtyd463)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirtyd463 &raquo;</TD></TR><TR><TD CLASS="quote">i say do it right, get it welded closed
just find a Awning shop or some company that has a MIG aluminum welding machine and just spot weld it closed. If you spot weld it and let it cool inbetween blasts of heat you will have absolutely no problems.</TD></TR></TABLE>
exaclty what i was going to say.
Old Jun 29, 2004 | 12:03 PM
Darton Sleeves's Avatar
Default Re: (f u z z)
Weld it...
Old Jun 29, 2004 | 12:58 PM
servion's Avatar
Default Re: Can JB Weld hold on a block? (BigMoose)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigMoose &raquo;</TD></TR><TR><TD CLASS="quote">My personal preference would be to drain the radiator, clean the surface thoroughly with acetone, roughen the surface with an abrasive if you can get at it, clean again with acetone, pull a slight vacuum on the cooling system to get the epoxy to flow a little into the porosity and use Devcon aluminum filled industrial epoxie #10610, in particular:
http://www.devcon.com/devconfa...id=15</TD></TR></TABLE>
listen to this guy
Old Jun 29, 2004 | 09:22 PM
dunkd's Avatar
i think im gonna drill it, tap it, then put a screw in it... i called around to the local builders and they all said the smae thing and that theyve had to do it several times and it works fine
Old Jun 29, 2004 | 09:27 PM
Default Re: (feri0)
you had better flush the block out after driling on it
Old Jun 29, 2004 | 11:07 PM
99blackcivicSi's Avatar
Same principal as fixing cracks in heads and blocks i have done both, most recently a chevy 350, i recomend you do it with the block out of the car and dissassembled, so you don't accidently **** up and drill all the way through to your sleeve that wouldn't be cool. just my .02cents though
edit: also for added protection you can accually weld it your choice though
Old Jun 29, 2004 | 11:40 PM
Default Re: (99blackcivicSi)
and welding would not require you to remove the engine
Old Jun 30, 2004 | 12:25 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirtyd463 &raquo;</TD></TR><TR><TD CLASS="quote">and welding would not require you to remove the engine </TD></TR></TABLE>
To do it correctly you remove the engine regardless
TGonie
Welding / Fabrication
Aug 3, 2013 02:05 PM
chippy
Nov 30, 2006 08:46 AM
-iLLuZioN-B18C1
Aug 4, 2004 06:19 AM
int3gra
Mar 2, 2004 10:02 PM
PSU-TEG
May 18, 2003 03:24 PM
