BUBBLE IN TIRE
Old Jun 28, 2004 | 03:53 PM
ShockerLude89's Avatar
Default BUBBLE IN TIRE
if anyone could help me it would be a big help, i have 17" rims with 40 series tires i was putting tire shine on my wheels and realized i have a bubble on the front right tire, side wall its not that big but im gonna be driving about 130 miles tomorrow and was wondering if its just gonna blow out?
Old Jun 28, 2004 | 04:05 PM
Jeff99Base's Avatar
Default Re: BUBBLE IN TIRE (ShockerLude89)
Dunno, its kinda a toss up. I hit a pot hole and broke the sidewall in a 50 series last fall. I drove on it for a day and was fine, but I didnt do anything crazy, and I doubt I went over 30 miles.
Old Jun 28, 2004 | 04:21 PM
Nikoli's Avatar
Default Re: BUBBLE IN TIRE (Jeff99Base)
more than likely it wont blow out, but i wouldnt ride on it more than necessary. i have this problem a couple of times. did you ride on it with little or no air?
Old Jun 28, 2004 | 05:08 PM
prelude1897's Avatar
Default Re: BUBBLE IN TIRE (95deckedlude)
Thats called an impact bubble. You should get that tire replaced asap. It might not blow, but it will get bigger.
Old Jun 28, 2004 | 05:28 PM
Default Re: BUBBLE IN TIRE (prelude1897)
its really little, what would happen if i let all the air out and filled it up again?
Old Jun 28, 2004 | 06:44 PM
Sc00teR_92h23's Avatar
its a sidewall bulge..
caused by the splitting of the material inside the sidewall or a broken bead (from who ever installed it ) air can leak through the bead and cause the sidewall to bubble..
can also be caused by a defective tire...
or a number of other things such as leaving it up against a curb too long etc...
should be under warantee go back to where you got your rubbers.. most companies have a road hazard warantee .. you pay the difference of the tread you used vs what a new tire has .. plus some little fees or what not but saves you some $$$... but should replace in pairs or rotate tha tone to the back if its on the front.. car will pull/vibrate ..
Old Jun 28, 2004 | 06:50 PM
4bidden's Avatar
Default Re: BUBBLE IN TIRE (JDSRV)
Get it replaced to be safe.
I drove on a Nitto with a bubble for quite a few miles, but I didnt feel safe the entire time.
Old Jun 28, 2004 | 07:59 PM
crdcz03's Avatar
Fortune Cookie Member
Default Re: BUBBLE IN TIRE (4bidden)
def get that replaced asap.
i was putting my tire on my rim a few months ago when i had just bought my SE wheels and it was pretty badly damaged and deformed portion of metal ripped the tire a lil bit when i was putting it on and caused a bubble... so i had to buy another tire.
it could blow at anytime!!! dont go under 50mph!!1
Old Jun 30, 2004 | 12:38 PM
fastlude69's Avatar
i had a bubble went to a amusement park came back out and it was flat so had to roll on a donut the whole way home and threw off my alignment thank god i get them for free and my car wasn't lowered yet
Old Jun 30, 2004 | 02:27 PM
ludelvr's Avatar
Default Re: (fastlude69)
Yah, that usually happens on lower profile tires. I've had it done to me about 6 times! haha, anyway, like they it has been said, you can get away with it for a while, but eventually, DO change it. I had two on one tire once and it progressively got larger. The integrity of the wall is compromised because the belts are torn or broken, so yah, eventually it will get bigger and constant pressure on it will hasten this.
Old Jul 1, 2004 | 12:07 PM
lostgirl18590's Avatar
I would get it replaced . I had the same thing happen to my tire and my tire blew with in the next 2 days .
95streetciv
Aug 27, 2011 01:50 AM
kaluwa3
32
Sep 23, 2007 04:07 PM
antiricer
Jan 25, 2007 09:09 PM
justininhifi
Jun 28, 2003 08:50 AM
Briman2021
May 8, 2003 01:56 PM
