How do i tell if my new motor is really JDM??
Old Nov 18, 2001 | 11:14 AM
B19CivicHB's Avatar
Default How do i tell if my new motor is really JDM??
Im got this engine from, apparently a bad place. It came dirty as hell, all the pulleys were rusted and every hose was cut. I would like to make sure it is LSD equipped and REALLY jdm... It is in fact stamped "B18C" so thats a plus and it has a "LSD" stamp on the tranny housing. its a P72 ecu for sure but thats all i know. HOw can i tell?
Old Nov 18, 2001 | 11:39 AM
chrisJ's Avatar
New User
Default Re: How do i tell if my new motor is really JDM?? (B18CivicHB)
to tell if its lsd for sure look thru the differential, if u can see straight thru it then it has LSD, if there is a medal bar thru it then it is not. if it is stamped b18c only, not b18c1 or b18c5 then u got urself a jdm motor. HTH's
Old Nov 18, 2001 | 01:11 PM
Big Teggie's Avatar
Default Re: How do i tell if my new motor is really JDM?? (chrisJ)
Isnt the jdm wiring harness different also, as a dead give away.
Old Nov 18, 2001 | 02:59 PM
B19CivicHB's Avatar
haha sweet... JDM it is! thanx for the info guys
Old Nov 18, 2001 | 04:16 PM
Suprdave's Avatar
**** JDM Motors...Japanese beat the **** outta their **** and never change the Oil.
All the Cut Hoses and stuff are gonna be a pain in the ***...I know from experience.
Suprdave
Old Nov 18, 2001 | 07:16 PM
CRX_VTEC's Avatar
Default Re: How do i tell if my new motor is really JDM?? (Suprdave)
That might not be true with Honda engines. No "racer" in japan would use a honda. They are kinda like econo cars there.. like civics are to us. Only exeption is the Type R and NSX. Xsi and CRX and SIR comw with B16 which we drool over are driven by students and housewives probably. So i dont expect much abuse from Honda engines that are JDM. But as far as them looking crappy when they get here ...its cuz of the engine scrapers. Thats how scrapers work..they just yank stuff out and dont give a crap about the engines. Then they pile them on top of each other like a pile of $hit. Thats why sometimes you get dents on the valve covers and broken sensors....When I buy engines for swaps.. I go visit the yards myself and make sure I get a hand picked engine that i see fit ..clean and compression checked. I also check the oil and tranny. Most of the engines you guys order are crap cuz people go to the yard and pick out all the good motors, you guys that get your stuff shipped get all the leftovers. I got a 98 LS for $700.. it was clean as hell and probably had less then 5K miles on it. I bought it back in 99 and it was stamped 6/98.. visit the yards and you can get lucky like I did. Order by mail and get a beat up engine no one wants..
Old Nov 18, 2001 | 08:52 PM
IntegraTypeRice's Avatar
Default Re: How do i tell if my new motor is really JDM?? (CRX_VTEC)
Do you know of good yards to go to in So Cal? That price for the LS motor is damn good.
Old Nov 18, 2001 | 09:26 PM
CRX_VTEC's Avatar
Default Re: How do i tell if my new motor is really JDM?? (IntegraTypeRice)
I was really lucky...my friend later that week after finding out about mine went and the best he could do was a 94 that was fairly clean. i guess i got lucky.. forgot the name of the yard...it was almost 3 years ago..but I do remember it was located in rancho cordova in N.cali.
Old Nov 19, 2001 | 05:31 AM
B18C5-EH2's Avatar
Former Moderator
Loved
I agree only that some JDM motors look like *** when you get them, but I also think that they're usually in good shape. Of all the JDM motors I've seen at the shop here, i've NEVER seen one with a gunked-up or even brownish valvetrain that is indicative of not changing oil. I'm talking at least 20 motors here.
The reason they cut everything is due to TIME. I've always been one to want to see the car my motor came out of - let's me know better how it was driven. There are some salvage yards here in the U.S, lke Import Auto Slavage in N.C that get WHOLE JDM front clips and do NOT cut anything when removing the swap.
We've got a '96-spec JDM ITR swap sitting on the floor here, with ECU, axles, linkage, WIRING HARNESS, etc. EVERYTHING. So, if you look hard enough, you can even get a complete JDM swap too.
Old Nov 19, 2001 | 11:26 AM
rtype11's Avatar
actually JDM owners do change their oil every once in a while, but most times they just use this stupid vaccuum system whereby you insert a hose in the oil filler cap location and suck out maybe 3 litres if lucky, when you get a JDM motor, run it for the first time on 3 1/2litres of oil (cheap kind) and one litre of ATF for an hour, this is the best internal engine shampooknown to man.
Old Nov 19, 2001 | 07:35 PM
B19CivicHB's Avatar
Default Re: How do i tell if my new motor is really JDM?? (rtype11)
what is ATF?
Old Nov 19, 2001 | 07:59 PM
B_CRUZ!'s Avatar
AutomaticTrannyFluid!?!
JDMb18civic's Avatar
ATF= automatic tranny fluid
Old Nov 19, 2001 | 08:00 PM
misledyouth's Avatar
New User
automatic tranny fluid. you forgot to tell htem to take the o2 sensor out cuase it'll screw the hell out of it. later
Old Nov 20, 2001 | 05:31 AM
rtype11's Avatar
Default Re: How do i tell if my new motor is really JDM?? (misledyouth)
why does the O2 come out, we are mixing ATF with oil, not fuel?
Let me know, I would be interested to know why
Old Nov 20, 2001 | 06:05 AM
B19CivicHB's Avatar
why would you put atf in with the oil????? that just doesnt sound right....
Old Nov 20, 2001 | 08:34 AM
Finest's Avatar
ATF is sort of like a cleaning agent. It'll scrub your oil pan, valvtrain, etc clean of oil deposits and all the grudge and crude that builds up when you don't change the oil for a long time.
Ask any "old school" Hot Rod mechanic and he'll tell you the same. It's a 50+yr proven technique.
Old Nov 20, 2001 | 11:24 AM
B19CivicHB's Avatar
Default Re: How do i tell if my new motor is really JDM?? (Prelude_RCR)
So i put 1 quart of ATF in with the oil (1q ATF + 3.1q oil) and just run normal for 3000 miles then change the oil without putting the ATF in?
Old Nov 20, 2001 | 12:41 PM
90accord1's Avatar
i beleive for the atf fluid you run it through a vacumm line and not in the actual oil line so that it combusts and runs throught he vavle train but im sure i could be wrong.
Old Nov 20, 2001 | 01:41 PM
killingtime's Avatar
You can ensure a JDM tranny housing by checking for VIN stamp.
The holes that mount the Vin havent been tapped for the VIN screws.
The B16B I have sat for a while, rust on axles and #2 spark plug hole.
Demian
Old Nov 20, 2001 | 04:09 PM
Krow's Avatar
I got a 98 LS for $700.. it was clean as hell and probably had less then 5K miles on it. I bought it back in 99 and it was stamped 6/98.. visit the yards and you can get lucky like I did. Order by mail and get a beat up engine no one wants.. [/QUOTE] What yard did you go too ?
Old Nov 20, 2001 | 05:46 PM
Katman's Avatar
Suprdave
I agree - JDM is ****. I can't stand it anymore.
Old Nov 20, 2001 | 06:49 PM
2080EK's Avatar
New User
Suprdave
I am sorry to hear your anger towards the people of JMD land!
h-duced
Sep 9, 2008 06:40 AM
free99
31
Jun 11, 2007 12:15 PM
MaxSterling
Jun 3, 2003 06:51 AM
Drag-On
Feb 14, 2003 12:36 PM
KOME
Nov 27, 2002 11:49 PM
