2001 Transmissions ?
Does anyone else have the 2nd gear grind problem in there 2001 ? Before I bought this one I tested it out, but I didn't go all the way to 9k to shift...... So yeh it grinds a bit when I shift from 1st to 2nd. Has anyone got there 2001 tranny fixed under warranty ? ....... I mean it should cover it... that's why you have a warranty...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Bagel »</TD></TR><TR><TD CLASS="quote">there is a TSB on this issue. check s2ki.com for the info.</TD></TR></TABLE>
the TSB applies to the '00 model years. However, depending on your dealer, they will diagnose the problem on a year by year basis. The thing is, once the gears are grinded a few times, they will ALWAYS grind thereafter.
*edit* forgot to mention, I've had zero issues with my '01 tranny. The only times I can remember it grinded was b/c of my error in shifting too fast (pointless). The hand always moves faster than the feet.
