would a 92-95 ex/si dist/dizzy work on a crx w/b16a1 (going obd-1)
Old Jun 27, 2004 | 07:07 PM
b16powwer's Avatar
Default would a 92-95 ex/si dist/dizzy work on a crx w/b16a1 (going obd-1)
whats up all, i am doing a obd-1 on my 91 crx si. i got the p28 ecu, 4-wire o2 sensor, 310cc rc obd-1 injectors, obd-0 to obd-1 harness from (newman, here on honda-tech) heres the deal, i am having a hard time finding a obd-1 dist, i know it came on the 94-95 gsr integras, would a LS obd-1 dizzy work, or a 92-95 si work, and how much should i look on spending, i really dont wanna pay more then $200. for a good or almost new working one. and want it to be complete.
a little help would be nice.
thanks all
Old Jun 27, 2004 | 07:38 PM
JDMotive's Avatar
Default Re: would a 92-95 ex/si dist/dizzy work on a crx w/b16a1 (b16powwer)
Either of those should work,but you might have to cut off an "ear" so it clears the vtec solenoid.
Old Jun 27, 2004 | 11:53 PM
rjay8604's Avatar
Default Re: would a 92-95 ex/si dist/dizzy work on a crx w/b16a1 (JDMotive)
for two hundred, you could get a brand new one from distributor king, and it'd be new. http://distributorking.com i'd go with that
Old Jun 28, 2004 | 12:05 AM
JDMotive's Avatar
Default Re: would a 92-95 ex/si dist/dizzy work on a crx w/b16a1 (rjay8604)
Damn..thats a awesome price! i wish i wouldve known about them a few years ago whenever i bought one from Acura for 3x that much.
Old Jun 28, 2004 | 06:04 PM
b16powwer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjay8604 &raquo;</TD></TR><TR><TD CLASS="quote">for two hundred, you could get a brand new one from distributor king, and it'd be new. http://distributorking.com i'd go with that</TD></TR></TABLE>
thanks alot rjay, will just order it from them.
Old Jun 28, 2004 | 06:19 PM
crackercr-x's Avatar
i used an obd1 ls distributor on my 89 crx with a b16, i cut off the bottom right ear completely and left the bottom left. only the top ear you will be able to get a bolt in, but the left ear you could use a washer and hold it in place that way.
Old Jun 28, 2004 | 06:25 PM
mr. carpenter's Avatar
Default Re: would a 92-95 ex/si dist/dizzy work on a crx w/b16a1 (crackercr-x)
i can show you pics of how i modded mine if you want to keep the obd0 dist. but you best bet is the one from dist. king.
Old Jun 28, 2004 | 06:38 PM
b16powwer's Avatar
Default Re: would a 92-95 ex/si dist/dizzy work on a crx w/b16a1 (mr. carpenter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr. carpenter &raquo;</TD></TR><TR><TD CLASS="quote">i can show you pics of how i modded mine if you want to keep the obd0 dist. but you best bet is the one from dist. king.</TD></TR></TABLE>
whats up pimp. if you can post pics. or email them to me at faraj77@aol.com, that will be great, thanks agian.
aimen from chicago
Old Jun 28, 2004 | 06:47 PM
these are of a 91' si dist. on a z6
Old Jun 28, 2004 | 06:50 PM
on the top one i had to dremel it out a little on the outermost part of the hole. after notching the sides i was able to get all three legs bolted down without hacking a leg off and still have adjustability of timing
Old Jun 28, 2004 | 09:08 PM
b16powwer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr. carpenter &raquo;</TD></TR><TR><TD CLASS="quote">on the top one i had to dremel it out a little on the outermost part of the hole. after notching the sides i was able to get all three legs bolted down without hacking a leg off and still have adjustability of timing</TD></TR></TABLE>
thanks alot on those pics. your rite, best bet is to get one from dist king.
Old Jun 28, 2004 | 10:05 PM
yeah plus it's brand new.
Old Jul 4, 2004 | 10:28 AM
b16powwer's Avatar
thanks alot all.
Old Jul 4, 2004 | 11:23 AM
fourthgenhatchB17's Avatar
Correct me if im wrong but the pics of the modified dizzy looks like its mounted to a SOHC VTEC motor. I think the guy who needs the info has a B16, so it really doesnt help him. If the distributor king has them for around 200 brand new, then thats the best price u will ever find.
edit: You cant keep the obd-0 dizzy when converting to obd-1.
Old Jul 4, 2004 | 12:14 PM
crxkane's Avatar
Default Re: would a 92-95 ex/si dist/dizzy work on a crx w/b16a1 (fourthgenhatchB17)
Yeah he needs the dizzy for a b16, and the 92-95 ex are a d16z (sohc) not doch. like posted before, a 94-95 ls/gs/gsr dizzy will work, 94-95 del sol dohc si will work. but as far as i know a 92-95 ex/si dizzy will not work.
correct me if i am wrong
Old Jul 4, 2004 | 12:33 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fourthgenhatchB17 &raquo;</TD></TR><TR><TD CLASS="quote">Correct me if im wrong but the pics of the modified dizzy looks like its mounted to a SOHC VTEC motor. I think the guy who needs the info has a B16, so it really doesnt help him. If the distributor king has them for around 200 brand new, then thats the best price u will ever find.
edit: You cant keep the obd-0 dizzy when converting to obd-1.</TD></TR></TABLE>
you're correct, my bad, i should've read the title better.
Old Jul 4, 2004 | 02:01 PM
you're correct, my bad, i should've read the title better.</TD></TR></TABLE>
I'll be sure to link anyone to this thread who is in need of the how-to on dizzy modifications for their SOHC vtec motor while using their old Si dizzy.
Old Jul 4, 2004 | 02:02 PM
ryanangelo212
Mar 18, 2013 12:23 AM
Dkahn18
Feb 18, 2009 04:41 PM
EGk3nrock
12
May 24, 2007 06:53 AM
obd1_crx
30
May 8, 2007 01:50 PM
rice4life
Jul 25, 2002 01:59 PM
