Hittin REV LIMITER AT 4GRAND
can anyone tell me if its normal for my d16 motor to be hittin the rev limiter at only 4 grand... from what im told i should be hittin it at atleast 6 grand, so does anyone know why my car is doin this and what could cause this
it swapped, b4 i had a d15b7, i kept my obd1 ecu, harness, dizzy, and fuel injectors
yea every once and a while i'll get the code for cyp sensor code 9 i believe it is
Ek Forever y0!
Re: (EGk3nrock)
Sigh, I'm not following you. So you have a d16 right?
What obd is the d16? If it's obd2 you need to get a conversion harness or just run the right ecu.
P05: 92-95 OBD-1 Civic CX
P06: 92-95 OBD-1 Civic DX
P07: 92-95 OBD-1 Civic VX
P08: 92-95 OBD-1 Civic D15 JDM
P0A: 94-95 OBD-1 Accord EX
P13: 93-95 OBD-1 Prelude Vtec
P14: 93-95 OBD-1 Prelude Si (non Vtec)
P27: 92-95 OBD-1 EG JDM Civic 1600 sohc
P28: 92-95 OBD-1 Civic Si/Ex
P30: 92-95 OBD-1 DelSol DOHC Vtec Si/EG SiR
P54-G31: 1997 Honda Accord 1.8 LS
P61: 92-93 OBD-1 Integra GSR
P72: 94-95 OBD-1 Integra GSR
P72: 96-00 OBD-2 Integra GSR
P73: 96-00 OBD-2 Integra Type-R (JDM & USDM)
P74/75: 92-95 OBD-1 Integra LS/GS
P75: 96-00 OBD-2 Integra LS/GS
P2N: 96+ OBD-2 Civic HX Coupe
P2P: 96+ OBD-2 Civic EX Coupe
P2E: 96+ OBD-2 Civic DX Coupe
P2M: 96+ OBD-2 NZ Civic SOHC VTEC
P2T: 99+ OBD-? Civic Si Coupe
yea i have a d16 now wit obd1 i kept my stock ecu, harness and dizzy drom my d15 motor when i did the swap so the d16 is runnin of an obd1 ecu and harness with a b7 dizzy
but the d16 came from an obd2 car so it was obd2 in my friends car but nows it obd1 runnin in my car
Re: (EGk3nrock)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGk3nrock »</TD></TR><TR><TD CLASS="quote">its a d16y7 and my ecu is p06 and it looks like the motor came from a p2e ecu</TD></TR></TABLE>
oh god lol......unless the p06 is tuned you are really not doing good for your engine if anything its bad(learned this from experience) you need a p2e i believe if thats the d16y7 one, not really sure if its a p2e or p2k. or get your timing set up where its suppose to be and get the p06 tuned with crome.
oh ok thanx alot, do u know any good sites that i can trust buyin one from and i would need to get the y7 dizzy back to put on that motor right, and i would also have to change things like my alternator and fuel injectors for that new harness???
Ek Forever y0!
Re: (EGk3nrock)
You should be able to utizile everything you have.
D-series distributors are interchangable.
Ebay, craigslist, here on h-t.
If you have trust issues go with here on h-t I guess.
Make sure you get a manual Ecu too. Auto ecu's are different.
4EN[sic]
03-25-2007 10:07 AM
tek_civic
07-17-2003 05:44 AM
