B18A1 block sensors
Old Jun 27, 2004 | 05:38 PM
vtecrx's Avatar
Default B18A1 block sensors
On the LS/VTEC that I am building for a friend (B18A1 block and GSR head) There are 3 sensors on the back of the block by the oil filter. The Oil pressure switch which had a single male bullet connector. There are two more.
One has two male bullet connetors (pretty sure that this is the fan switch)
The other one has a green plug with two terminals.
can someone verify that I am right about the fan switch and tell me what the green plug is. The only integra manual that I have is for the OBD1 integra and it is different.
Thanks for any info
Andy
Old Jun 28, 2004 | 04:27 AM
vtecrx's Avatar
Default Re: B18A1 block sensors (vtecrx)
does anyone know? the only sensor that I could think of that it has the possibility to be is a knock sensor, but I did not think that the early LS engine had those. I am wiring it up right now and would hate to have to add more wires after I have already re-loomed the engine harness.
Old Jun 28, 2004 | 05:23 AM
AychTwenee2's Avatar
for sure its an ls block? I have an ls block and it only has the fan switch and oil pressure, no green plug!!?? Weird....cause the only other plug that would be back there is a knock sensor, but on a vtec block only, not ls, and the plugs are usually gray.
Old Jun 28, 2004 | 05:47 AM
vtecrx's Avatar
Default Re: B18A1 block sensors (VeeTekCrx)
I am 100% positive that it is a B18A1. I guess I will just not wire to it since I have all of the important connections. Maybe some of the old ls blocks had a knock sensor?
Old Jun 28, 2004 | 07:03 AM
RACINTWEEK's Avatar
2 of them are your knock sensor and fan switch
i never saw three on any b series
my 92 LS only has 2 by the oil filter
sh!ft
27
Sep 12, 2014 04:59 AM
turbosol18
12
Sep 26, 2007 07:23 PM
rebo0t
10
Jun 26, 2006 01:02 PM
SPOOLINmatt
Jun 20, 2005 09:29 AM
baonest1
Oct 3, 2002 09:27 PM
