HELP!!! Noise after Rear Disc conversion...
Old Jun 27, 2004 | 03:20 PM
beedoublejay's Avatar
Default HELP!!! Noise after Rear Disc conversion...
I just put Integra brakes on my 1996 CX civic hatchback.
There is a repedative knocking noise coming from my rear passenger side wheel when driving. Any ideas on what I might be? I also replaced the pads on the rear disc.
TIA
Old Jun 27, 2004 | 03:43 PM
Default Re: HELP!!! Noise after Rear Disc conversion... (beedoublejay)
Anybody?
Old Jun 27, 2004 | 06:12 PM
bump it...
Old Jun 27, 2004 | 06:53 PM
murtnabila's Avatar
any more details? Have you put it on jack stands and tried to see what it is?
Old Jun 28, 2004 | 05:46 PM
C uR eX's Avatar
did you tighten all the bolts to the upper/lower/compensator arms and also the trailing arm bushing bolts? was the hub (bearing) damage? actually did you reatain or use your stock LCA/compensator/upper arms?
you rear might be off align if you don't use your stcok one or atleast of the sme years car. i did a swap for a customer b4 and after installing it using integra arms into his EG..his alighment was totally off causeing it to swirve and make noise..soi use his stock one, and it fixed the problem..
Old Jun 28, 2004 | 05:55 PM
thanks for all the input, i am going to get i aligned asap
Old Jun 28, 2004 | 09:05 PM
Lord Helmet's Avatar
you might want to resurface the brake rotor too.
elnoyl
24
May 30, 2009 05:38 AM
88 EF Hatch
Suspension & Brakes
Mar 3, 2009 06:22 PM
dudeomega2000
Apr 26, 2007 09:28 AM
DOHC-DX
11
Sep 18, 2002 06:47 AM
h22dc2
Aug 17, 2002 07:14 PM
