maintenance required light
Old Jun 27, 2004 | 03:05 PM
bearboy80's Avatar
Default maintenance required light
I read 3 different way to turn off the maintenance light.
1. push the botton on the green box underneath the dash
2. stick your key into the hole on the cluster
3. hold the odometer reset button
my question is how do i know which method i go with for my 3 different hondas?
Old Jun 27, 2004 | 03:25 PM
timmy8151's Avatar
Default Re: maintenance required light (bearboy80)
It should be in your owner's manuals. For integras, you just hold the reset button under the steering wheel.
Old Jun 27, 2004 | 04:59 PM
PnX-R's Avatar
Simple... On most Honda's if there's a little key hole in the instrument cluster, you stick the key in it to reset the little block of color next to it..
If there's a digital odometer on your vehicle, just hold down the odometer reset or RESET button on the instrument cluster and turn the key on. Hold the button until the Maint Reqd light shuts off..
Old Jun 27, 2004 | 08:47 PM
bearboy80's Avatar
Default Re: maintenance required light (PnX-R)
so i guess only ones with mechanical odometer and does not have hole on the cluster have the reset box underneath the dash.
TimM888GT
Jan 29, 2015 08:42 AM
1clean01
Honda Civic (2001 - 2005)
Jan 18, 2015 04:25 PM
9.3.S.I.L.U.D.E.
18
Aug 20, 2009 01:50 AM
Dc2 Powered
Aug 1, 2004 02:33 AM
Gavino
Dec 11, 2002 08:18 AM
