rpms idle when jump
Old Jun 27, 2004 | 02:21 PM
rtpassini's Avatar
Default rpms jump up and down at idle.
(yeah i messed up the title. lol)
(h23 into sol)
when i first start it, it runs smooth. all seems good. when i rev it. itll hit around 2500 then get all weird. ill let off the gas, then a code comes up (14, IAC i believe) the rpms jump up and down, and when i give it gas itll bog down. any ideas? bad IAC?
Old Jun 28, 2004 | 05:46 PM
devnull's Avatar
Either bad IAC or you need to bleed your cooling system. Maybe vacumm leak but with code 14 I'd say bleed you cooling system (of air not fluid)
Old Jun 30, 2004 | 09:36 AM
rtpassini's Avatar
yeah we tried that...
but now that i got some stuff fixed that was wrong, itll work now.
and then after a while nothing came out.....it was weird. maybe ill try it again.
piotrush
Oct 7, 2006 01:38 PM
premo_si
Aug 29, 2006 07:33 PM
rtpassini
Jun 27, 2004 02:42 PM
B18 CYA
Jun 15, 2004 12:24 PM
