Mugen N1 ECU
Old Jun 27, 2004 | 06:08 AM
Austinbionic316's Avatar
Default Mugen N1 ECU
Will this ECU work in the B18c motor?
Old Jun 27, 2004 | 06:45 AM
pb16b's Avatar
Default Re: Mugen N1 ECU (Austinbionic316)
stupid question... it'll work on a lawnmower if it's wired right.
Old Jun 27, 2004 | 06:49 AM
Default Re: Mugen N1 ECU (pb16b)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pb16b &raquo;</TD></TR><TR><TD CLASS="quote">stupid question... it'll work on a lawnmower if it's wired right.</TD></TR></TABLE>
Well I wasnt sure. I mean it says it would work for the RSX, S2000, and b168 and ITR motor.
Old Jun 27, 2004 | 12:14 PM
pb16b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Austinbionic316 &raquo;</TD></TR><TR><TD CLASS="quote">
Well I wasnt sure. I mean it says it would work for the RSX, S2000, and b168 and ITR motor.</TD></TR></TABLE>
rsx and s2000 ecu's are different, b168 (sounds like an aircraft code) and itr motor all use different ecu's... if you're talking about a mugen program, it'll probably work on all of those except the b168...
Old Jun 27, 2004 | 01:40 PM
rsx and s2000 ecu's are different, b168 (sounds like an aircraft code) and itr motor all use different ecu's... if you're talking about a mugen program, it'll probably work on all of those except the b168... </TD></TR></TABLE>
I know its different ECUS but I thought any B series part would fit on any B series.
Old Jul 1, 2004 | 05:04 AM
pb16b's Avatar
I know its different ECUS but I thought any B series part would fit on any B series.</TD></TR></TABLE>
yeah b series parts do fit just about any b series... up to a point... the ecu's go by obd type... obd 1 obd2a obd2b
Old Jul 1, 2004 | 05:09 AM
Kendall's Avatar
Yes, the Mugen N1 ECU, when ordered for a B series will work for any B18C, however in a GSR motor, it won't allow the secondary butterflies to operate. Depending upon your car, you may need to purchase a conversion harness as it may not plug right in. You're better off going with a Hondata setup that's specifically tuned for your application rather than a universal program such as Mugen's N1.
Old Jul 1, 2004 | 05:58 AM
pb16b's Avatar
Default Re: (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">Yes, the Mugen N1 ECU, when ordered for a B series will work for any B18C, however in a GSR motor, it won't allow the secondary butterflies to operate. Depending upon your car, you may need to purchase a conversion harness as it may not plug right in. You're better off going with a Hondata setup that's specifically tuned for your application rather than a universal program such as Mugen's N1.</TD></TR></TABLE>
so you're saying for instance a mugen n1 ecu for a b18a will work for any b18c? you did say ordered for a b series and i believe b18a is a b series... it won't work...
keepinitrehaal
Mar 20, 2008 11:30 PM
lux
Honda S2000
28
Mar 6, 2007 06:58 PM
White_S
Honda S2000
Apr 19, 2005 09:52 AM
97ShLude
Honda S2000
Apr 10, 2005 07:44 PM
Hoosier Daddy
Feb 1, 2004 12:20 PM
