question of spoon throttle body
Old Jun 26, 2004 | 10:44 PM
QQ's Avatar
QQ
Default question of spoon throttle body
can spoon throttle body direct blow on to the usmd integra r intakes manifold or i need the jdm spec?
Old Jun 26, 2004 | 11:10 PM
emotionisdead's Avatar
Very Emergency!!
Default Re: question of spoon throttle body (QQ)
the spoon throttle body is just an oem honda one that is tapered out to 70mm. bolts right up.
Old Jun 26, 2004 | 11:19 PM
QQ's Avatar
QQ
Default Re: question of spoon throttle body (SpoonDC2R)
so will that spoon throttle body help get some power or i should custom port my oem throttle body?
Old Jun 26, 2004 | 11:49 PM
type one's Avatar
I have spoon TB and i felt the gain but in the scheme of things you could port your oem TB to 68mm or 69 mm for a fraction of the cost and while the workmanship wouldn't be AS good, it'll still do the job...
Alternatively get yourself a technospirit TB which has a ported opening and corresponding larger butterfly, whereas spoon only has larger opening at 70mm.
Old Jun 27, 2004 | 05:49 AM
DA6righthand's Avatar
how bout you get a bbk throttle body, those run about 250-300 bux but are just as good as spoon and alot less in cost....
Old Jun 27, 2004 | 09:48 AM
splitime's Avatar
There is a guy here that can bore the OEM TB out and people state his work is top notch. It costs like 100 bucks and includes a new butterfly, couple bucks more and I believe he also port matches to the intake manifold. Search around H-T, I believe he has a sponsor banner up.
edit: Assuming the quality is as people have said, this is a MUCH better deal than a Spoon TB which is mearly tapered out and stock inside diameter. He IS a sponsor, http://www.maxbore.com/
Old Jun 27, 2004 | 04:47 PM
92RED Hatch's Avatar
Default Re: question of spoon throttle body (splitime)
Here is the guy who does them on h-t....... good stuff!
http://www.gbronline.com/jorgep/index.html
Old Jun 27, 2004 | 08:10 PM
splitime's Avatar
Default Re: question of spoon throttle body (92RED Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92RED Hatch &raquo;</TD></TR><TR><TD CLASS="quote">Here is the guy who does them on h-t....... good stuff!
http://www.gbronline.com/jorgep/index.html</TD></TR></TABLE>
Actually, he is no longer Big Bore... its http://www.maxbore.com.. same guy though.
Spaceballsthelunchbox
Oct 14, 2005 08:30 PM
Trbospnkr
May 8, 2003 11:18 PM
EGsex
Dec 10, 2002 03:49 PM
57one
Oct 16, 2002 01:22 PM
"SPOON EG"
Jul 26, 2002 11:25 AM
