Difference between Coupe and hatchback mufflers?
Old Jun 26, 2004 | 07:40 PM
CooBlueDAB's Avatar
Default Difference between Coupe and hatchback mufflers?
I reciently got muffler service on my 2000 Civic EX 2 Door coupe and they screwed up majorly. The centerpipe with the resonator is not the right dimensions (it was supposed to be a stock replacement), and the mounting bars that connect the pipe to the rubber mounts, appear to be 3 times as long. This pipe seems shorter, than my rusted stock one. My general question is, did this dude just get the wrong pipe? perhaps a hatch pipe? Or is he just %)&#)%&* up and I need to get my money back and go someplace else, he keeps giving me crap about how he can make it all better by using a torch and bending the pipe. This things doesn't come close to fitting, its so low, it hits the axel now on hard left turns and the resonator hits the body, rattling like tin cans......
I need some advice... arg....
Old Jun 26, 2004 | 07:53 PM
CooBlueDAB's Avatar
Default Re: Difference between Coupe and hatchback mufflers? (CooBlueDAB)
Bump .... ack, please respond, I need to know if I should take it back and get money then leave to another place for my center straight pipe
Old Jun 26, 2004 | 07:57 PM
GoGoGadgetVtec's Avatar
if they screwed it up, take it back and bitch till they get it right.
Old Jun 26, 2004 | 08:02 PM
CooBlueDAB's Avatar
Default Re: Difference between Coupe and hatchback mufflers? (GoGoGadgetVtec)
I kind of figure the answer to this is yes, but is torching and bedning the muffler to work a bad idea? and does it hold effects like premature rusting and weakening, I need concrete stuff to throw at this guy, and the BBB has been notified of his buisness. It is because of that alone that he called me back and is working on it.
Old Jun 27, 2004 | 10:12 AM
Cynical 1's Avatar
Coupe and hatch do have different pipe length.
Take it back, you should have gotten a warranty.
Old Jun 27, 2004 | 11:17 AM
Chickenball's Avatar
Default Re: Difference between Coupe and hatchback mufflers? (Cynical 1)
If you have a coupe then the muff is going to be LONGER than the HB muff. So whether or not they gave you the HB is a definite no. I think you should take it back or get another shop to look at it for a second opinion. Then go back and take all the **** off your car and ask for your money back. That is just ridiculous! Hope this helps.
Dringo
May 31, 2010 10:15 AM
1slwEK
Feb 1, 2008 07:16 PM
JDM_COUPE94
May 2, 2007 06:17 PM
ka-nife_
Apr 17, 2006 10:43 PM
