help with P30 (2nd gen) intake manifold install- runs - NO CEL
Old Jun 26, 2004 | 05:15 PM
gringo7718's Avatar
Default help with P30 (2nd gen) intake manifold install- runs - NO CEL
i have a 1st gen b16 in my 91 crx. i switched to the P30 intake manifold and a 94 integra GSR throttle body. the GSR TB has the FITV mounted on the TB, instead of the old FITV attached to the manifold. i have bypassed the FITV on my new GSR TB and current setup . i have everything installed and connected and it runs with NO CEL; BUT IT IDLES AT 1500... PLEASE HELP. i have swapped MAP sensor, IACV, and adjusted TPS to 4.52 DC at closed throttle. please help
since then, i have tried spraying carb cleaner to the tb gasket and the manifold gasket but nothing really seemed to show signs of a leak. anyone please point me in the right direction
Modified by gringo7718 at 11:48 PM 6/28/2004
Old Jun 27, 2004 | 11:01 AM
gringo7718's Avatar
Default Re: help with P30 (2nd gen) intake manifold install- runs - NO CEL (gringo7718)
HELP
Old Jun 28, 2004 | 02:50 PM
gringo7718's Avatar
Default Re: help with P30 (gringo7718)
Old Jun 28, 2004 | 02:55 PM
4drEF's Avatar
Keyboard Humorist
throttle cable too tight?
Old Jun 28, 2004 | 03:08 PM
gringo7718's Avatar
Default Re: help with P30 (4drEF)
the throttle isnt the problem. i also adjusted the idle screw on the TB.
i am thinking it is a small leak somewhere. any other ideas
unless coolant must flow through the FITV/Throttle body. here is a pic of a 94 integra tb.
https://honda-tech.com/zerothread?id=801422
Modified by gringo7718 at 12:25 AM 6/29/2004
Old Jun 28, 2004 | 03:30 PM
91civicEX's Avatar
is that warm idle? what is cold idle?
Old Jun 28, 2004 | 03:59 PM
gringo7718's Avatar
Default Re: help with P30 (91civicLX)
cold 2000 and warm 15-1800. maybe i have to do the old FITV trick, open it and screw it in all the way?
Old Jun 28, 2004 | 04:48 PM
gringo7718's Avatar
YES it was the old FITV trick!!!! i was about to tear it all apart again and i tried one last thing and thats it. thanks for your help guys.
TopGear_
Aug 18, 2009 11:15 AM
newtype_racing
Oct 10, 2008 11:03 PM
1baddturbosi
Mar 19, 2007 04:06 PM
matto2413
Jun 1, 2005 11:36 PM
.BULLET.
12
Apr 1, 2003 11:54 PM
