Transmission Issues : questions
Old Jun 26, 2004 | 04:22 PM
solbats's Avatar
Default Transmission Issues : questions
My transmission on the 93 del sol si is crapping out. Was fine at first then a couple
times I had the experience of it not wanting to go into gear after going to nuetral
at a stop.
Now it's gotten to the point where I have to turn the car off slide it into first with
the clutch depressed and start the car release and go. I can upshift just fine one
going. If I try to go to first from neutral it wont budge into gear.
Is this the clutch or a hydro problem? It doesnt grind going into gear and the
tach doesnt slip or spin up on catching the clutch.
One thing I noticed was a leak in the transaxle, I have it parked and was going to
jack it up tomorrow and check the filler bolt.
Advice appreciated.
Hell I was going to put the y8 s40 tranny in post turbo anyway. This might be
the motivation to do it now...
Old Jun 26, 2004 | 04:32 PM
HXvtec's Avatar
Default Re: Transmission Issues : questions (solbats)
welcome to the world of d series trannys. first i would say check the tranny fluid, that might be the problem. if not time to get another one. and go boost.
Old Jun 26, 2004 | 04:35 PM
loco_ese's Avatar
my suggestion would be to start with the simplest things first. Check your master slave cylinder resovoir (next to the brake master cylinder res.) to make sure you are full of fluid. Next do a check of the slave cylinder to see if there are any leaks as it seems that the clutch is not being fully released, thus not allowing you to go into first. It doesn't cost anything more than a bottle of dot3 hydro fluid and less than an hour of your time. Hope this helps.
Old Jun 26, 2004 | 04:54 PM
solbats's Avatar
Default Re: Transmission Issues : questions (loco_ese)
I checked the resevoir, it's full. Is the white plastic disc in it supposed to be free floating?
The brake cylinder has a stick on it to deress that white plastic disk.
Anyway where do I check the slave cylinder itsel for leaks?
Any other things to check out?
Old Jun 26, 2004 | 04:57 PM
sohcvtec1995's Avatar
syncros sound like they are pretty much done for. but check the fluid, put syncro mesh in. Or just get another tranny. you can find a d series tranny real cheap. And it will be cheaper than rebuilding yours.
Old Jun 26, 2004 | 04:58 PM
HXvtec's Avatar
Default Re: Transmission Issues : questions (sohcvtec1995)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 &raquo;</TD></TR><TR><TD CLASS="quote">syncros sound like they are pretty much done for. but check the fluid, put syncro mesh in. Or just get another tranny. you can find a d series tranny real cheap. And it will be cheaper than rebuilding yours.</TD></TR></TABLE>
100 bux for mine y0
Old Jun 26, 2004 | 05:07 PM
solbats's Avatar
how could it be syncors if I can upshift fine. I know what syncros that are bad feel like
from the vr4 world. You can double clutch a bad syncro.
I think it's a hydro issue. Could it be a clogged line?
Old Jun 26, 2004 | 05:35 PM
JDM EJ1 95's Avatar
if you have a leak i would check the fluid if you havent already.. then i would bleed the clutch line
Old Jun 26, 2004 | 05:51 PM
solbats's Avatar
thanksa ton guys,
I have some work to do in the morning.
this thread answered my questions, I did asearch on bleeding the lines
which I wouldnt have known without your responses.
thanks!
https://honda-tech.com/zerothread?id=787039
syncros suggestion!
i love turbo honda
Apr 27, 2009 07:38 PM
MCJ420
Jul 22, 2008 04:28 PM
94solchick
Sep 13, 2004 01:10 PM
ar5enal
Apr 27, 2003 06:44 PM
tilt
Oct 7, 2002 01:22 PM
