wiring rem start, where is neutral pos switch wire in lower drivers footwell...
Old Jun 26, 2004 | 04:17 PM
W0oT's Avatar
Banned
Default wiring rem start, where is neutral pos switch wire in lower drivers footwell...
i think my fsm shows it as a white/black wire, i'm trying to wire my remote start on my alarm and need a more accessable place to reach the wire than way up under the wheel.... please help.
Old Jun 26, 2004 | 04:41 PM
W0oT's Avatar
Banned
Default Re: wiring rem start, where is neutral pos switch wire in lower drivers footwell... (Majin Vegita)
anyone? link 2 site?
http://members.tripod.com/~dia....html
Old Jun 26, 2004 | 09:05 PM
az17xscrub's Avatar
There isn't a neutral safety sensor on our cars
Old Jun 28, 2004 | 05:58 PM
W0oT's Avatar
Banned
Default Re: wiring rem start, where is neutral pos switch wire in lower drivers footwell... (az17xscrub)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by az17xscrub &raquo;</TD></TR><TR><TD CLASS="quote">There isn't a neutral safety sensor on our cars</TD></TR></TABLE>
no ur right there is no "sensor" it's a switch and the clutch pedal pushes it when you depress the pedal.
Old Jun 28, 2004 | 07:06 PM
goforbroke's Avatar
MEAT PATTY
The two wires are
blue with black strip
and black with the silver dots
I use the button as a push button start switch on my dash. It can me a pain the *** to get to.
Old Jun 28, 2004 | 08:34 PM
W0oT's Avatar
Banned
Default Re: wiring rem start, where is neutral pos switch wire in lower drivers footwell... (goforbroke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goforbroke &raquo;</TD></TR><TR><TD CLASS="quote">The two wires are
I use the button as a push button start switch on my dash. It can me a pain the *** to get to.</TD></TR></TABLE>
you think those wires could be in the lower kick panel bunched w/ the rest???....
i know how much of a b*tch it can be to get to i just replaced my whole pedal assembly and didn't think of this then. :kick ***:
Old Jun 29, 2004 | 01:25 AM
7PSI CRX's Avatar
The Starter RELAY is in the drivers' footwell.
Old Jun 29, 2004 | 05:56 AM
W0oT's Avatar
Banned
Default Re: wiring rem start, where is neutral pos switch wire in lower drivers footwell... (7PSI CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 7PSI CRX &raquo;</TD></TR><TR><TD CLASS="quote">The Starter RELAY is in the drivers' footwell.
uhhh huh.... that's not what i'm looking for though, unless u can tap into one of those wires to bypass the n.p.s.
Modified by Majin Vegita at 1:38 PM 6/29/2004
Old Jun 29, 2004 | 01:03 PM
goforbroke's Avatar
MEAT PATTY
If I remembe correctly the wires go to the fuse box in the back of it.
Old Jun 29, 2004 | 01:14 PM
7PSI CRX's Avatar
See the red wire tap?
That by-passes my clutch switch.
What you want to do is engage the starter, no?
That's the place....
The starter relay will engage the starter, NO MATTER WHAT!
Old Jun 29, 2004 | 04:55 PM
az17xscrub's Avatar
what i said a few posts up was a neutral safety switch that detects if the car's in gear or not. sorry that's a different thing
you're talking about the clutch pedal switch. what i did was follow the switch from the back wires. it should have 2 wires in there. it leads into a large loom in the back of the fusebox. its quite accessable once the fuse box is has been taken out. one wire is a constant 12v and the other is a switched 12v when clutch is depressed.
W0oT's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 7PSI CRX &raquo;</TD></TR><TR><TD CLASS="quote">See the red wire tap?
eww red scotchlock
nice though very nice, what wire did u tap sinor? and what was the polarity of it if you don't mind me asking.... i'm sure it's in my fsm somewhere.
thanks for the excellent info though.
Old Jun 29, 2004 | 07:09 PM
W0oT's Avatar
Banned
7PSI CRX
u give me new hope and your making my life soooooooooo much easier... thanks... . now do you happen to remember what that wire color is?
that better gator? lol
Old Jun 29, 2004 | 07:52 PM
W0oT's Avatar
Banned
i'm guessing blue/black. according to my fsm
Old Jun 29, 2004 | 08:00 PM
0554's Avatar
88's you dont have to have the clutch pressed in to start it
Old Jun 29, 2004 | 08:19 PM
goforbroke's Avatar
MEAT PATTY
Default Re: (88crex)
True but when you have a whole entire 90 civic si wiring harness in your 88std from front to back you need it. Its funny though I spent almost half a day trying to figure out why my car wouldnt' start and low and behold it was this stupid damn switch.
Old Jun 30, 2004 | 01:32 AM
7PSI CRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Majin Vegita &raquo;</TD></TR><TR><TD CLASS="quote">i'm guessing blue/black. according to my fsm</TD></TR></TABLE>
Correct, giving the Blue/Black @ the Starter Relay a GROUND will bypass the clutch switch.
As for the ignition switch itself, you need these connected also.
1.Black/Yellow (IGN #1)
2.Blue/White (Blower Motor)
3.Yellow (IGN #2)
4 Black/White (Starter Solenoid)
And if you want the radio to come on with the remote start there is another wire to connect, I don't know right now what color that one is.
Old Jun 30, 2004 | 05:50 AM
W0oT's Avatar
Banned
3.Yellow (IGN #2)
you the man u the man, i'm gonna attemp to wire it today. won't the radio come on if i leave it on? i got the rest of the wires and colors off 12volt.... don't we need a relay in the starter solenoid circuit? to reverse the polarity? maybe just on my alarm.
tvman
Audio / Security / Video
Mar 26, 2006 09:33 AM
92hybrid+
Sep 15, 2005 06:38 PM
EGDC2CIVIC
Apr 22, 2005 02:46 PM
Hatch It
Apr 11, 2005 12:49 PM
MickREXor
Oct 16, 2004 08:54 PM
