compustar question
Old Mar 25, 2006 | 12:32 PM
tvman's Avatar
Default compustar question
im installing the compustar 2w900fmas...do i need to make a by pass because of the clutch lock?
Old Mar 25, 2006 | 01:20 PM
fcm's Avatar
fcm
Old Fart
Default Re: compustar question (tvman)
Yes, very simple, connect the black (CN2/2) "Status Output" to the starter relay side of clutch interlock switch, [most Honda/Acura] may be a blue/black wire. 94
Old Mar 25, 2006 | 02:18 PM
tvman's Avatar
Default Re: compustar question (fcm)
thanks...do all the ones with the negatvie symbols have to be tied together?
Old Mar 25, 2006 | 03:06 PM
tvman's Avatar
also...do i need to cut any wire in the ignition?
Old Mar 26, 2006 | 09:33 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tvman &raquo;</TD></TR><TR><TD CLASS="quote">thanks...do all the ones with the negatvie symbols have to be tied together?</TD></TR></TABLE> Not sure what you mean.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tvman &raquo;</TD></TR><TR><TD CLASS="quote">also...do i need to cut any wire in the ignition?</TD></TR></TABLE>The only wire you would need to cut would be the started wire and only if you are installing starter kill, all other connections are parallel connections. 94
zenon8890
Audio / Security / Video
Aug 1, 2007 11:32 PM
JDM_Frijoles
May 18, 2006 10:17 PM
projectPSI
Mar 13, 2006 02:54 PM
Dunc
Mar 20, 2005 12:26 PM
W0oT
17
Jun 30, 2004 05:50 AM
