Timecert VS Helicoil, options, advice needed
Old Jun 26, 2004 | 02:52 PM
VtecKiDD's Avatar
Default Timecert VS Helicoil, options, advice needed
Ok, i have 1 helicoil already, its holding, but 2 other head bolts stripped out on my gsr. I have ordered AEBS headstuds. Can i use the headstuds still if i helicoil the 2 that just stripped out, do i need oversized studs, etc. I searched, found some good info, but i still want opinions, heres a link to my other thread
https://honda-tech.com/zerothread?id=901429
Old Jun 26, 2004 | 03:28 PM
Sack Master's Avatar
Default Re: Timecert VS Helicoil, options, advice needed (VtecKiDD)
I'll just say that I don't trust helicoils for anything.
Old Jun 26, 2004 | 04:10 PM
Jon5240's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecKiDD &raquo;</TD></TR><TR><TD CLASS="quote">Ok, i have 1 helicoil already, its holding, but 2 other head bolts stripped out on my gsr. I have ordered AEBS headstuds. Can i use the headstuds still if i helicoil the 2 that just stripped out, do i need oversized studs, etc. I searched, found some good info, but i still want opinions, heres a link to my other thread
https://honda-tech.com/zerothread?id=901429</TD></TR></TABLE>
I work with Helicoils almost everday, never had a problem with them...
As far as needing an oversized bolt, no you can use your existing bolts
i get good prices on helicoils let me know
Old Jun 27, 2004 | 12:42 AM
pr0honda's Avatar
Default Re: Timecert VS Helicoil, options, advice needed (Jon5240)
time-sert all the way.. contact donf on the board he does blocks..
Old Jun 27, 2004 | 06:36 AM
Tbone's Avatar
Just tap the holes bigger and get larger studs if you want it to be like factory. I had a block timecerted by RS and the only thing I didn like is that I needed to use custom short stud on the timeceted hole. it was also one of the dowl pin holes so we couldnt use a dowl anymore.
Old Jun 27, 2004 | 02:55 PM
VtecKiDD's Avatar
Default Re: Timecert VS Helicoil, options, advice needed (Tbone)
Tbone can you provide me some more info like on where to buy the materials? i cant find anyon that sells larger head studs, and the tap for it. Rocket told me someone in Florida does it, but i dont have their name or number
Old Jun 27, 2004 | 03:58 PM
DonF's Avatar
Timesert the block, you do not need different studs, or dowel pins. The problem with Heli-coils in the block is they are to short for proper grip strength. If the block has been overheated to much to make the threads go bad, you may have other problems. Call Justin at Buckhead Motor Works on Hilderbrand Ave in Atlanta, and he can give you a hand.
Old Jun 27, 2004 | 04:14 PM
bs-inc's Avatar
Default Re: Timecert VS Helicoil, options, advice needed (DonF)
since we're on the topic, i have a question...
the guy im buying this from told me to weld aluminum back on and then retap.
will timecert work for my application?
Old Jun 27, 2004 | 04:24 PM
david@didrace.com's Avatar
Default Re: Timecert VS Helicoil, options, advice needed (bs-inc)
If you're welding that whole big hunk of aluminum back in you just retap.
Old Jun 27, 2004 | 05:38 PM
Tbone's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">Timesert the block, you do not need different studs, or dowel pins. .</TD></TR></TABLE>
Just to clarify, I wasnt saying it had to be done that way, I'm just telling him my experience when RS machine did it to my old block.
So Don, if you do timecerts on the front dowl holes o0n a vtec block, the timecert isnt larger thyan the diameter of the dowl itself? I wonder if Rs just used a generic timecert on mine?
Old Jun 27, 2004 | 07:05 PM
rainmanEK's Avatar
big strong guy
Default Re: Timecert VS Helicoil, options, advice needed (Sack Master)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sack Master &raquo;</TD></TR><TR><TD CLASS="quote">I'll just say that I don't trust helicoils for anything. </TD></TR></TABLE>
Helicoils Are Way Proven, In all of my Road Racing cars I would would never think Twice about using any size HeliCoil.....
Eric
Old Jun 27, 2004 | 09:30 PM
johnzm's Avatar
Default Re: Timecert VS Helicoil, options, advice needed (rainmanEK)
i am in the same boat
heli coils are suposed ot be no good becasue they dont make a length long enough for the head bolt to properly screw in...
i have foud that a time sert does make a good long insert that will grab more of my bolt/stud
Old Jun 27, 2004 | 09:53 PM
evilxkid's Avatar
Default Re: Timecert VS Helicoil, options, advice needed (johnzm)
Timecert all the way. i ran helicoils on my b20 once and they came right out, so i had to get bigserts(made by timecert) to fix what the helicoils did.
o'h and the timecert factory is right down the street from my work so they where convieniant.
Old Jun 28, 2004 | 11:45 AM
DonF's Avatar
Default Re: Timecert VS Helicoil, options, advice needed (evilxkid)
The timesert in no larger than the dowel so it does not interfear with the dowel. This is a long insert, originally to repair alum. Cadillac blocks.
Naudlee
Aug 10, 2006 10:21 PM
TSX TEX
Jul 13, 2006 04:20 PM
Ruben19
Jan 5, 2006 05:48 PM
Mikey3000
Jan 4, 2006 03:50 AM
B_CRUZ!
Mar 18, 2002 09:26 PM
