B16 SIR II SWAP
yes, you can use your stock power steering components, but you might need a gsr bracket to mount the pump. try to mount the pump on the stock braket first. cause when i did a b16a2 swap for my friend. i tried the stock bracket. it did not line up properly, so i tried the gsr bracket then the pump bolt right up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2lua »</TD></TR><TR><TD CLASS="quote">yes, you can use your stock power steering components, but you might need a gsr bracket to mount the pump. try to mount the pump on the stock braket first. cause when i did a b16a2 swap for my friend. i tried the stock bracket. it did not line up properly, so i tried the gsr bracket then the pump bolt right up.</TD></TR></TABLE>
you are correct
you are correct
raverx3m
Dec 27, 2011 04:56 AM
HATCHingMN
Jun 4, 2007 07:56 PM
nasaproracer
Jul 6, 2004 11:06 PM
