Popping sound on Jspec R engine...
Old Jun 25, 2004 | 09:51 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Default Popping sound on Jspec R engine...
Long post but please read/help:
I have a '99 JDM R engine with ~18k miles. Stock except for the JDM header, Icebox and Comptech filter I just cleaned and a Comptech exhaust. At high rpm's (8200-8400rpm's) I hear a popping noise from the car. Sounds like it's from the exhaust but not sure. I just started getting that sound about a week or two ago. At first it was with the JDM ITR ECU and now with the Mugen ECU. Is it detonation? I have a Halmeter a/f ratio meter and at 8200-8400rpm's it is showing that I'm running rich. I also run 93octane gas. (maybe it's bad gas? I usually use Chevron but I used Citgo this last time)
Here's what I've done so far:
I recently changed out the cap and rotor (OE Honda parts). I've done this twice before so it's nothing new to me. Could it be my wires are bad? I just ordered some NGK wires so I'll be replacing my old Magencore wires that were from my old GSR set-up. The NGK iridium plugs are a couple months old. When I pulled them out they were white on the top part above the electrode. Could that mean I'm running lean? The rest of the plug is black like I'm running rich. I put my B&M FPR back on and raised the pressure to 46psi, still within stock specs but at the high end. I also added 2-3% fuel on my VAFC from 7k - 9k rpm's. But I am still getting the popping noise.
I also checked my timing and I have it at 16 degrees, per specs and I did a compression check and I got 220, 220, 210, 210; still strong across the board.
Just a little while ago, I put my JDM ECU back in, reset my VAFC and added about 1-2% fuel from 7-9k rpm's. I ran the car and I'm not getting the popping sound anymore.
I've run both ecu's before with no popping so I want to know what could be causing this problem? I'd like to use the Mugen ECU for track days but if it's potentially a danger to my engine I'd like to know why and fix it.
Thanks for any help/suggestions. Let me know if you have any other questions about my setup and what I've done.
Old Jun 25, 2004 | 10:36 PM
Fuuma0083's Avatar
Default Re: Popping sound on Jspec R engine... (Gee3)
possibly the gas isn't burning competely in the combustion chamber and the excess gas is burning in your cat/exhaust pipes.
(above statement isn't for detonation)
edit: the sound of detonation sounds like ball bearing dropped on a dish.
Old Jun 25, 2004 | 10:46 PM
Gee3's Avatar
Default Re: Popping sound on Jspec R engine... (Fuuma0083)
Thanks for giving me an idea of what detonation sounds like. I've never heard it before so any wierd sound coming from my engine/car makes me nervous.
So what do you think I should do to correct this if it excess gas? I was getting the popping noises before I made the changes to the fuel pressure and the VAFC.
Thanks!
Gary
Old Jun 26, 2004 | 06:52 AM
Gee3's Avatar
anymore suggestions?
Thanks!
Fook_me_honda
May 12, 2007 11:24 AM
gambit1982
16
Dec 31, 2005 02:52 PM
Gee3
Jun 30, 2004 05:37 AM
crxtreme27
Jan 25, 2003 12:29 PM
D-SPEED
Sep 1, 2001 10:58 PM
