spoon 2 ply head gasket
Old Jun 25, 2004 | 04:07 PM
98ITRWhite's Avatar
Default spoon 2 ply head gasket
i am planing on building my motor, and i just wanted to know if i used the spoon 2ply head gasket if i would need to have my block O ringed. and if it just goes on with no machine work.
Old Jun 25, 2004 | 04:15 PM
BlueR's Avatar
Default Re: spoon 2 ply head gasket (98ITRWhite)
the block just needs to be decked and the headgasket goes right on
Old Jun 25, 2004 | 04:17 PM
98ITRWhite's Avatar
Default Re: spoon 2 ply head gasket (BlueR)
what do you mean by ''decked''
Old Jun 25, 2004 | 04:18 PM
BlueR's Avatar
your machine shop will know
basically this will create a good mating surface for a good seal
Old Jun 25, 2004 | 04:19 PM
ZygSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98ITRWhite &raquo;</TD></TR><TR><TD CLASS="quote">what do you mean by ''decked''</TD></TR></TABLE>
Milled/machined ... just to make sure its perfectly flat (to make sure the head gasket seals nicely).
Old Jun 25, 2004 | 04:20 PM
98ITRWhite's Avatar
Default Re: spoon 2 ply head gasket (zygspeed)
but if i were to use just a oem honda one i would not have too.
Old Jun 25, 2004 | 04:21 PM
BlueR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98ITRWhite &raquo;</TD></TR><TR><TD CLASS="quote">but if i were to use just a oem honda one i would not have too.</TD></TR></TABLE>
still need to either way
Old Jun 25, 2004 | 04:22 PM
ZygSpeed's Avatar
Would probably be a good idea in either case.
Not much of an issue unless there are some scratches and/or stuff on the block upper surface.
Old Jun 25, 2004 | 04:23 PM
98ITRWhite's Avatar
cool thanks i am off to the machine shop then.
Old Jun 25, 2004 | 04:25 PM
ZygSpeed's Avatar
Machine work plus a 2 ply head gasket will noticably increase your compression, and Cam gears might be a good idea (especially depending on any additional head work that may have been done).
Modified by zygspeed at 8:35 PM 6/25/2004
Old Jun 25, 2004 | 04:27 PM
98ITRWhite's Avatar
yea i have the cam gears on the car now but i just am gathering up all the parts that i need for this future build up.
Old Jun 25, 2004 | 04:28 PM
BlueR's Avatar
sounds like you're all set
Old Jun 25, 2004 | 04:33 PM
Mike K's Avatar
to properly deck a block, you need the whole thing disassembled.
just use some copper spray. you don't need to deck your block, especially if it was fine before rebuild (ie: not overheating)
Old Jun 25, 2004 | 04:36 PM
98ITRWhite's Avatar
Default Re: spoon 2 ply head gasket (Mike K)
no the motor runs strong now but i just want some more power. where do i get copper spray auto parts store?
BlueR's Avatar
without all the details...
we don't really know if it is disassembled or not...
we're answering on assumptions
Old Jun 27, 2004 | 07:34 AM
Mike K's Avatar
copper gasket spray is available at any auto parts store. v8 guys love this stuff. they usually have to put it on every single gasket on their motor. lol.
btw, you'll probably pick up 2hp on a good day with that headgasket. i'd say stick to tuning, or put the money elsewhere.
but if you're really feeling the need for higher compression, just buy an OEM one, drill out the rivets and use the bottom layer. it's thinner than the spoon and with the copper spray, i have never seen one leak more than any other 3-piece OEM gasket. plus it's WAY cheaper.
spoon = maybe .2 or .3 compression gain and $150??
1 layer = solid .5 compression gain $60-ish
Old Jun 27, 2004 | 08:59 PM
Matty.'s Avatar
I will be putting the head on any day now and will be using the Spoon headgasket. I had the head resurfaced 10 thou and will be using JUN III's. This is a ITR with p73-00's.
Do you guys think that I'll be alright with this setup?
Oh yeah I will be using cam gears too hoping to gain a few more hp by adjusting these. Wont this put my valves closer to the piston?
Thanks!
Old Jun 28, 2004 | 12:06 AM
Eddiebx's Avatar
yeah just go with a stock gasket and pull out the middle layer and copper spray it, u will be fine.
oh and you dont need to drill out the rivets, they are soft as hell, i can literally bend them out with my finger nails, hehe
Old Jun 28, 2004 | 06:59 AM
Matty.'s Avatar
not trying to thread jack but anyone think I will be safe with this setup. (see above post)
Thanks!
Old Jun 28, 2004 | 09:37 AM
Mike K's Avatar
Default Re: (gumtape_deathmatch)
yea you'll be fine.
Old Jun 28, 2004 | 11:40 AM
Matty.'s Avatar
Default Re: (Mike K)
Thanks for the reassurance!
Honda must have a lot of clearance to start with.
I am thinking I lost about 0.030" of clearance with the combination of gasket and resurfacing, plus the bigger lobe and longer duration of the Juns .......will this afford me much adjustability on the cam gears or will I be pretty limited if I want to be safe?
Old Jul 6, 2004 | 11:11 AM
Matty.'s Avatar
BUMP
Jdmb16sir2
Oct 26, 2007 12:23 PM
VVV
Jul 30, 2007 03:37 PM
jdm ek9 101
Sep 21, 2006 09:42 AM
Master23
21
Feb 23, 2006 03:33 AM
topspeed86
Jan 6, 2005 05:18 PM
