Smaller Amp Fuse cause problems?
Old Jun 25, 2004 | 02:10 PM
mjrage's Avatar
Default Smaller Amp Fuse cause problems?
My alternator isnt charging the battery, car is dead, just for *****, I look in the fuse box and in the alternator place is a smaller fuse like a 7.5 in a 10 or something along those lines.
Would this call my alternator not to work properly? I looked and it is spinning and the belt is moving even with the fuse the way it was.
Could this of caused my battery to die? I already bought an alternator, I was more or less just curious for future reference, I havent installed it yet, but maybe id charge the battery and test it.
Old Jun 25, 2004 | 02:55 PM
mjrage's Avatar
Default Re: Smaller Amp Fuse cause problems? (mjrage)
ttt
Old Jun 25, 2004 | 07:20 PM
cruzan007's Avatar
Putting a lower amp fuse wouldnt damahe anything. The only thing that might happen is the fuse might blow under regular operation since it might not be able to handle the load.
Old Jun 25, 2004 | 08:09 PM
mjrage's Avatar
Default Re: Smaller Amp Fuse cause problems? (cruzan007)
which would then render that component useless?
lakeviewman
Aug 8, 2025 02:07 PM
Juju2010
Apr 14, 2015 11:15 AM
d0wnShiFt
Jan 6, 2011 03:00 PM
rasta420
Nov 6, 2002 08:41 PM
