Car Idle's Ok, but car won't barly move with some gas
Old Jun 25, 2004 | 07:51 AM
PolySquared's Avatar
Default Car Idle's Ok, but car has heavy bog!
My car was turbo'd before, and I just recently put eveything back into stock. Everything is stock except my JE 9:1 pistons and eagle rods. As everything else is stock, along with some advance timing adjustment, the car idle's "somewhat" ok. If I apply some throttle, the car has "HEAVY" bog. I get complete bog as soon as I apply a bit of throttle. There are no check engine lights, which seems a bit odd. Also, my fuel pressure gauge reads at 40.
Can I get some help please!
Modified by PolySquared at 5:40 PM 6/25/2004
Old Jun 25, 2004 | 07:36 PM
taz77's Avatar
New User
Default Re: Car Idle's Ok, but car has heavy bog! (PolySquared)
test your tps and map...
Old Jun 25, 2004 | 09:26 PM
Default Re: Car Idle's Ok, but car has heavy bog! (taz77)
well, I already try adjusting the TBC and the timing. Its really weird! I can't get a code either!
Old Jun 26, 2004 | 09:32 PM
mod5's Avatar
Try checking your O2 sensor... clean it.
Old Jun 26, 2004 | 10:58 PM
G U E C O's Avatar
did u check ur tps?
Old Jun 26, 2004 | 11:16 PM
mmuller's Avatar
Mad Scientist
how's your cam and ignition timing?
Old Jun 27, 2004 | 06:53 AM
alfonzo's Avatar
Default Re: Car Idle's Ok, but car has heavy bog! (mmuller)
did you have your timing belt off? maybe you got it off a tooth . that would explain the problem . even if you did not have it off i would still check it.
Old Jun 27, 2004 | 07:24 AM
KMaxwell's Avatar
it sure sounds like you have your tps plug and map plug switched
Old Jun 27, 2004 | 09:04 AM
Default Re: (KMaxwell)
I'm new with the term "tps", but I'll work on that. Yes, my timing belt was off and I slapped that back on.
Old Jun 27, 2004 | 10:08 AM
crazy eyez killa
Guest
Posts: n/a
Default Re: (PolySquared)
That happened to me the other day and it turned out to be one of my sparkplugs, was bad.
**** Bosch Platinum
Old Jun 27, 2004 | 10:09 AM
Tushner's Avatar
TPS = throttle position sensor.
Spoolup98
Honda CR-V & Element
May 18, 2019 03:21 PM
mouab18c1
Aug 10, 2012 12:30 PM
AllMotorHB
39
Sep 24, 2010 12:41 PM
paradigm_shift
May 31, 2009 12:11 PM
scrEaMO Kyle
Oct 23, 2005 07:23 PM
